Brake and Clutch Oil - Use S.A.E Heavy Fluid
Old 05-24-2012, 08:47 PM
eric_1982's Avatar
eric_1982
eric_1982 is offline
I am a rookie in the world of rebuilding cars and have a lot to learn. I just got my Grandpa's 1958 F100. The first thing I want to do is get it running and back on the road. Since it has not been driven in so long I want to make sure i have the brakes looked at. Looking at the firewall I see the two places were fluid goes for the Brakes and Clutch. Looking at the caps it just says "Use only S.A.E heavy fluid". I am not sure if i can use Dot 3 fluid or if I should use something else. Sounds like the brake lines are all original and fluid has never been added. Does any one know much about this and have any recommendations of what fluid to use? Would the clutch and Brake lines use the same fluid?
Old 05-24-2012, 09:36 PM
critterf1's Avatar
critterf1
critterf1 is offline
DOT 3 in both.
Old 05-25-2012, 08:23 PM
spurredon's Avatar
spurredon
spurredon is offline
Yes, they both use brake fluid. If it has been sitting a long time, there's a good chance lines will need to be replaced. No sense filling up the master before you change lines. Give them a good looking over first.
Old 05-25-2012, 08:24 PM
spurredon's Avatar
spurredon
By the way, welcome to FTE! The best thing you could do is buy yourself a shop manual for the truck!
Tom Norton
07-23-2022 04:53 AM
02GrayPowerStroke
09-16-2018 02:30 PM
eric_1982
05-28-2012 06:12 PM
Nice Work Truck
10-25-2009 11:44 PM
baz
08-16-2003 11:07 AM
Quick Reply: Brake and Clutch Oil - Use S.A.E Heavy Fluid
