Problem with turn signals and sidemarkers
Hi, I'm wondering if anyone has had the same problem as me and if they can help. The side markers and turn signals are acting up on my 79 f100. When you turn on the left turn signal nothing happens, same with the front and back. But they all work when the hazard lights are on. I'm no electrician but if this is an easy fix please help. Thanks.
on
The hazards work using a different flasher unit. The one for your turn signals might just need to be replaced.
Put on your hazards and note which flasher under the dash is in use. Then replace the other one.
They look like this one: Flasher link
You're saying the hazards work, yet the LEFT turn signal does NOT work - is it safe to assume the RIGHT side DOES work? If the hazards work and the right side works, you've proven out the bulbs, sockets, and turn signal flasher. The only thing left is the switch itself. That would explain why both LEFT FRONT and LEFT BACK do not work.
You can prove this theory by disconnecting the turn signal switch coupler under the column. Lock the turn signal lever in the RIGHT position. If your RIGHT side is working, you will see continuity between the BLUE and WHITE/BLUE wires on the turn signal side of the connector (NOT the side coming from the truck). Next lock the turn signal lever in the LEFT position. If you don't see continuity between the BLUE and GREEN/WHITE wires in the same connector, replace the turn signal switch.
Any certain method on removing the wheel? I can get the nut off but not sure how to get the wheel off, it's on there.
The H/D flasher can be subbed for the turn signal flasher (and was with trailer tow), but not the other way around.
I chased similar tail light/side marker/turn signal issues on my truck for a couple months. New turn signal switch, new flashers, new bulbs, and they still wouldn't work right. It ended up being the actual tail light sockets. Ordered a couple new ones from LMC, and after replacing them everything worked great again.
The only difference in these lamps is the Bronco/Econolines have a foam rubber seal that just peels off.
Lotta 1975/91 Econolines in junkyards, so there's no need to buy these parts from LMC and then pay shipping charges from KS to lawd only knows where.
breadstick
03-22-2012 09:27 PM
1974Ranger
02-01-2010 11:22 PM
bmccartney
10-05-2009 11:41 AM
