Ford F150 EB (or 5.0) vs Toyota Tundra - Page 6 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2009 - 2014 F150
Reload this Page >
  #76
Old 06-01-2012, 03:40 PM
blueovelboy's Avatar
blueovelboy
blueovelboy is offline
blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.
well just to chime in, today i had to pull a 7000 # trailer over the hill to Santa Cruz and then back. well i got it there and never had a problem, but had to leave early and go get the other trailer the dude driving the trailer broke down. as i pulled up i noticed it was a friend who just bought a Toyota 2012 4x4 tundra extra cab 4 door. we think he blow his rear end out. in 4 hi it would still pull thats how he got to the pull out where i hooked up to it. it got towed to the dealer hes got just over 8000 miles on it. now its a dam nice truck got every thing one could need. but dam 8000 miles and already blows differential. we put it in 2x and put it in gear and drive line spins and its making a lot of grinding noise and makes the truck jump and shake a LOT.
  #77
Old 06-01-2012, 04:11 PM
85e150six4mtod
85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Tundra rear axles are either 10.5" for those with the tow package or 9.5" without.
2007 Toyota Tundra Rear Axle - 4Wheel & Off-Road Magazine
What you describe sounds like a cleaned out ring and pinion. (did that to an 8" Ford myself)
That would be a pretty good trick with an axle like that.
Front axles seem to be a problem with the Tundra, but not so much the rear.
That sure would make you question your purchase though....
  #78
Old 06-02-2012, 07:09 AM
bery53
bery53 is offline
bery53 is starting off with a positive reputation.
Aftermath
OK! Got the jasper,went by the shop to take a peek at the insides of the old moter,Not pretty,have ran Amsoil and same filter for the first life of the truck! Inside of moter was a mess!! Sludge!Varnish!Ware on all the cam lobe's lord knows what the bottom end looked like.Mech said he would call me a show me the inside of moter's run with regular oil, he does this for a living and was not a Amsoil fan.Well im not one now,we will see.Anybody used BG MOA in a moter as an additive?Contains ZINK i think.Anyway would like to know thoughts on oil and service,I know there are a million !!
  #79
Old 06-02-2012, 08:47 AM
King Ranch's Avatar
King Ranch
King Ranch is offline
King Ranch is gaining momentum as a positive member of FTE.
I do a lot of snowmobiling, there was a company that did an extensive test on oils and two stroke engines with break down and sludge. Amsoil was very low on quality in this test.
  #80
Old 06-02-2012, 09:02 AM
tex25025's Avatar
tex25025
tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
You are just going to be spinning your wheels on that one. The only thing that you could probably take away from that topic(which is a thread onto itself) is what not to use, but even that will probably be subject to debate.
Best that I can say, do your own research (not knowing what other people have done for their own research isn't going to help you much in this endeavor), find what makes you and your budget happy and go with that.
As to service, I typically follow what is in the manual. If they have it broken down by normal and severe service (or some derivative of that) then I usually do the severe service, regardless if the truck goes through hell and back. Might be more of a placebo effect, but my trucks are clean.
  #81
Old 06-02-2012, 09:19 AM
YoGeorge
YoGeorge is offline
YoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud of
There are a million opinions out there but the most obvious one is to run Motorcraft 5W20 and Motorcraft filters, change every 5000 miles or so. I have 105k miles on my 4.6 E150 running mostly that combo and it is tighter than when it was new. So do many other folks with 200k and 300k miles on their engines.
George
  #82
Old 11-13-2014, 09:33 AM
Ray Lancon
Ray Lancon is offline
Ray Lancon is starting off with a positive reputation.
Buy American. For me personally, its just that damn simple
  #83
Old 11-13-2014, 09:40 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
Toyota quality seems to have suffered some since it went Racing. All in all it is a great 4X4. The 4X4 is probably much better/stronger than the Ford 4X4 system. All in all Fords is perty good. That Ford frame from about 3 feet back is great. The very front not so good. Adding cross brackets up front to it will help.
Real world embarrassment.
  #84
Old 11-15-2014, 12:22 AM
Greg B
Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
That illustrates one of the many reasons that Ford is the best selling pickup truck for 38 years and counting.
  #85
Old 11-16-2014, 07:06 PM
xr7gt390's Avatar
xr7gt390
xr7gt390 is offline
xr7gt390 has a great reputation on FTE.xr7gt390 has a great reputation on FTE.xr7gt390 has a great reputation on FTE.xr7gt390 has a great reputation on FTE.
I was on some Tundra web sites. Lot of Ford bashing on, didn't think I could be part of that negativity so I didn't signup. I've had great service from all my F150's really no reason to look anyplace else.
  #86
Old 11-23-2014, 08:51 AM
Ray Lancon
for me as well
Yup, I followed a thread on this post over to a Tundra site and noticed a HUGE amount of Ford bashing there.
This one fella....BigTexTundra (google him I dont even want to post a link) reminds me of those rabid Obama voters.
My gosh he is way over the top on the Ford bashing.
On this site, even if you drive something else, there is no bashing for your decision.
That being said, I am a long time Ford truck owner have owned several. Just bought a new 2014 Ford XLT with the 5.0. I wanted tried and true and proven that had served me well in the past so I came back to the dance with the one that brung me originally.
  #87
Old 11-24-2014, 05:39 PM
xr7gt390's Avatar
xr7gt390
xr7gt390 is offline
Yep, I read that guys posts. It's almost like he's been brainwashed or something.
  #88
Old 11-25-2014, 03:49 PM
GuyGene's Avatar
GuyGene
GuyGene is offline
GuyGene is gaining momentum as a positive member of FTE.
Yep, I'm on that Tundra forum too, and old BigTex - the boy does not like Fords. I also noticed somebody there did a thread asking everyone's age on that Tundra forum - no wonder, most of those boys are just that - real boys. Nothing wrong with youth, but a bit o' studying in ye olde school of hard knox does temper some people down a mite. I leave a place if people start being disrepectful.
30coupe
2009 - 2014 F150
47
05-24-2017 11:36 AM
dirtydeeds
5.0L Coyote
45
02-19-2017 11:04 AM
stever761
New Member Introductions
04-26-2016 02:33 PM
ocasio0727
Ford vs The Competition
15
05-12-2014 07:36 PM
mudshack
2009 - 2014 F150
89
04-23-2014 01:46 PM
Quick Reply: Ford F150 EB (or 5.0) vs Toyota Tundra
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
