Replace Whole Tensioner or Just Pulley?
Since my idler pulley literally fell out of the truck on my trip to California in March, I thought it might be a good idea to replace the pulley on the tensioner since it's original as well.
I was curious what most of you do when replacing this part: Do you replace the entire tensioner or just the pulley itself? Whatever way I choose, I'll probably be picking up the part at Napa early next week to install it before my Memorial Day trip.
I'm assuming it's a pretty easy job, right? I have to change the oil, air and fuel filter, too, so I thought I'd knock everything out at once in an evening after work.
Thanks!
Thanks!
Thanks for the input guys!
Are the Ford tensioners that much better quality that I should avoid the parts store ones? If so, I'll put in an order through Horizon simply because they are much closer to me and I should have the part in hand within two days.
Thanks again!
Thanks PJ! I called two local dealers and they are trying to take me for $180, or about double Silver State or Horizon. NOT going to happen!
Thanks again!
Thanks again!
When I did my dual tensioner I had to do it twice. Once with aftermarket parts. Then again with OEM parts. So in the long run its best go with the OEM stuff. It may cost you a bit more but you wont have to do it twice.
I went out to install my new tensioner pulley last night and realized for the first time the truck has two idler pulleys as well as the tensioner. The dealer in Salinas replaced the lower, ribbed one, but the upper, smooth one is still original, so I figured I might as well order that one up before diving into the tensioner so I don't have to do the job twice.
I got a part number off the top idler pulley, but I wanted to confirm with you guys that it is the right one before ordering:
Thanks in advance!
F6TE19A216GA
Also, do you guys typically have to remove the fan shround to replace the tensioner? I tried getting my T50 socket on there last night and it seemed like the shroud was going to get in the way real quick. Is it pretty easy to remove, or do you have to remove the fan as well?Thanks in advance!
Thanks in advance!
F6TE19A216GA
I cant help about the number
Thanks in advance!
F6TE19A216GA
