Replace Whole Tensioner or Just Pulley?
#31
I found this # parts
Serpentine Belt Idler Pulley (Upper, no grooves)
(Ford) F6TZ-8678-GB
(Motorcraft) YS-267
(Napa) 38052
(Autozone) 231057
Serpentine Idler Pulley (7-rib 94 only)
(Ford) F5TZ-8678-A
Serpentine Belt Idler Pulley (Lower Grooved, 8 rib)
(Ford) F6TZ-8678-HB
(Motorcraft) YS-268
(Autozone) 231048
(Ford) F6TZ-8678-GB
(Motorcraft) YS-267
(Napa) 38052
(Autozone) 231057
(Ford) F5TZ-8678-A
(Ford) F6TZ-8678-HB
(Motorcraft) YS-268
(Autozone) 231048
#32
The part numbers are exactly the same on both boxes. On the bottom of each part label there are three sets of numbers; the set on the left is the same on both, the set on the right looks like a manufacture date, but I can't determine what the set in the middle might be, and those are different between the two boxes. The picture is below:
#34
(Ford) F6TZ-8678-GB
(Motorcraft) YS-267
(Napa) 38052
(Autozone) 231057
(Ford) F5TZ-8678-A
(Ford) F6TZ-8678-HB
(Motorcraft) YS-268
(Autozone) 231048
(Ford) F6TZ-8678-GB
(Motorcraft) YS-267
(Napa) 38052
(Autozone) 231057
(Ford) F5TZ-8678-A
(Ford) F6TZ-8678-HB
(Motorcraft) YS-268
(Autozone) 231048
Last night I took a picture of the two pulleys and the part numbers on the boxes so I can send it to Horizon Ford if I need to.
Thats WEIRD.
#35
In this specific case, don't buy the pulley with the shields on it, or return it immediately if it has the shields. I guess you could theoretically modify it to make it work, but you shouldn't have to do that with a brand new Motorcraft part.
