hi my names corey and im new to the forums. i have a 2006 ford f250 king ranch 4x4 with the 6.0. i drove the truck the other night and it was running fine. it threw a little fit when i was leaving dinner where it didnt wanna start the first couple times i tried but started right up on the 3rd time like normal. drove it around town some more turned the truck on and off 2 different times before i headed home. stapped to get a drink on my way home in a drive thru turned the truck off so i could order and the truck has not started since then. i have replaced the cam shaft and crank shaft sensors and i can hear the fuel pump kick on and it is filling my bowl (i have checked that). i know its not my batteries i tried to jump the truck and ive also had them on charge where i keep working on the truck and trying to start it. alternator is also new. at this point i dont just wanna throw parts at the truck. any suggestions on what my problem could be?
ok i just checked my FICM and voltage stayed at 48 the entire time i tried cranking it and "cycling" on and off so its not that. i also unplugged the ICP sensor from the valve cover and still nothing. will the fuel bowl still fill if the fuel cut off switch is flipped?
Just try resetting it. Push down on the rubber boot.
