Airbag Light On
Old 05-25-2012, 09:02 PM
pacepace's Avatar
pacepace
pacepace is offline
Airbag Light On
I just bought a 08 f150 4.6L 4x4. It has the airbag light on and the guy told me it was from the seat belt indicator being unhooked underneath the passenger seat. I looked today and there is a connector about 3 inches long that was unconnected and push it back in. Would this be causing it because it is blinking 51 code. Do I just reset the light by disconnecting the battery or could this not be the problem and be something else?
Old 05-25-2012, 09:16 PM
MCDavis's Avatar
MCDavis
MCDavis is offline
Check to see if the clock spring recall was completed last year. The warning sign was the air bag light.
Old 05-26-2012, 01:49 PM
pacepace's Avatar
pacepace
pacepace is offline
I went to the ford website and typed my vin# in and there are no recalls for it and looked on the forum and there is only one recall for 08 f150 with roush performance package.
Old 05-27-2012, 10:21 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,432 Likes on 2,347 Posts
Check your codes document them, and then erase them. Disconect the battery long enough for the system to bleed dead. Reset and see. After you reset you may hear a whine in the dash, that will be the bags recharging. Depending on the code you may need to replace the clockspring if the light reappears.
Suicidal
1997 - 2003 F150
09-04-2015 01:26 PM
Crimson04
1997 - 2003 F150
10-09-2014 07:01 PM
MichaelKnight
1983 - 2012 Ranger & B-Series
01-26-2011 09:51 AM
jpm2591
06-17-2005 03:46 PM
jcjc2u
Electrical Systems/Wiring
03-30-2003 12:20 PM
Quick Reply: Airbag Light On
