WEEKEND PROGRESS
Old May 12, 2012 | 08:43 PM
oldmerc's Avatar
oldmerc
oldmerc
WEEKEND PROGRESS
Here is some of what I have been up to . Replaced pitman arm and joined T5 to engine . Now I can figure out how I am going to build a transmission mount.drive shaft,pinion seal,remove front end sheet metal,etc.etc.etc.
Old May 12, 2012 | 09:52 PM
Dano78's Avatar
Dano78
That's a NICE looking flatty. Pretty straight forward T-5 swap? Is that a GM T-5?
Been toying with the idea of ousting the 215 inline 6 for a flathead in my '53 Mainline.
Old May 12, 2012 | 11:04 PM
51PanelMan's Avatar
51PanelMan
Keep the 215 and just dress it up. Everyone has a flathead, but not an OHV!
Old May 13, 2012 | 12:27 AM
Dano78's Avatar
Dano78
Now see.... if you talk me into keeping it, you won't get a free exhaust manifold...
Oh i just have this 'thing' about the nice low rumble of a V8.... kinda like a junkie on a coke farm. And nothing produces a sweet low rumble any better than an old Flathead with dual 2" straight pipes at idle.
Old May 13, 2012 | 08:21 AM
oldmerc's Avatar
oldmerc
oldmerc
That T5 came out of a 1989 C#$%y S10 , Adapter kit from Speedway . You just have to make up a little clip to hook the throwout bearing return spring onto . Cost of swap. Tranny $180.00,Adapter $352.00 Including shipping and brokerage , Donor driveshaft (for slip yolk)$30.00 , 9 inch S10 clutch disc $58.00
Old May 13, 2012 | 08:36 AM
Greg M-47's Avatar
Greg M-47
Wow, that flathead is real nice. Almost too nice to be putting it in your merc. Should be on display.
Greg M-47
tinman52's Avatar
tinman52
Welder User
I just finished the T-5 swap in my truck. I cut the center out of the old x member and made a new one from 2x4 box tube (bolt in). I also had to brace up the old one where the brake and clutch pedals mount.
I could not use a stock S-10 clutch disk as the center springs hit the crank bolts. I had to buy the disk made specially for this swap
Old May 13, 2012 | 09:10 AM
oldmerc's Avatar
oldmerc
oldmerc
Have not worked out all the fine technical engineering type details yet but I am sure now after input on another thread from Ross and Havi that the only alteration will be a trany mount extending back from the existing x member .
Old May 13, 2012 | 01:41 PM
tinman52's Avatar
tinman52
Welder User
I wish I could tell you it is that simple......but I can't.
Old May 13, 2012 | 02:18 PM
Dano78's Avatar
Dano78
Rowing gears through a modern 5speed behind a flathead for around $600? Seems like a no-brainer to me. Every swap has it snags... hell it seems everything I do has snags.
the_justin
Nov 26, 2010 09:57 AM
ksmith203
Jan 3, 2007 01:37 PM
Narwhal
Exhaust Systems
Jun 28, 2005 09:16 AM
Karm
Mar 31, 2003 10:56 PM
