'96 F-150 5.8 EGR stumble / surge
Old 05-09-2012, 11:27 AM
IJRoorda's Avatar
IJRoorda
IJRoorda is offline
My truck is a 1996 F-150 with a 5.8L. Ever since I bought the truck, it has had a sort of surging stumble at around 1200-1500 RPM. It is more noticeable under a slight load - for example, slowly driving up a hill - but I can reproduce it by opening the throttle with the truck sitting still. I recently replaced my PCM to solve another issue, and I was hoping this issue would disappear as well; the other issue is gone, but this stumble remains.
I did some poking around and discovered that it is definitely EGR related - it goes away if I remove the vacuum line from the EGR valve. I stuck a beer can with a small hole in it (maybe 1/8", I poked it with an awl so not precise) between the EGR valve and the intake manifold as a restrictor plate (similar to the mod the 4.9L guys do), and the stumble seems to be gone.
I know the OBD-II trucks use a DPFE sensor instead of an EVP sensor like the EEC-IV system, so I'm assuming that this will probably set a trouble code once I drive the truck a little more. I would like to fix it correctly, but I'm not sure where to go next. Any suggestions?
Old 05-09-2012, 01:27 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
Sounds like the EGR control solenoid is bad and leaking.
Old 05-09-2012, 01:35 PM
IJRoorda's Avatar
IJRoorda
IJRoorda is offline
Ian, thanks for the response. I have tested that resistance across the EVR solenoid is within range, but it sounds like you are saying that vacuum is leaking through the EVR when it should not be. I suppose I can test that with a vacuum pump/gauge, right?
Is the EVR strictly on/off, or is it pulse-width modulated to control the level of vacuum applied to the EGR valve?
Old 05-09-2012, 01:38 PM
Conanski's Avatar
Conanski
Conanski is offline
The EVR is modulated by the computer but it should be 100% closed at idle so that should be easy to test.
Old 05-14-2012, 10:25 AM
IJRoorda's Avatar
IJRoorda
IJRoorda is offline
My vacuum pump is loaned out and I haven't gotten it back yet, but I was at the boneyard this weekend and picked up a couple of EVR's off other trucks. I swapped one in last night and removed my beer can restrictor; after a quick test drive, it appears that the problem is gone. When I get my vacuum pump back, I will test the new one vs. the old one and see what I find.
1995F250351
02-28-2015 01:28 PM
Brenda Lamka
12-22-2014 09:00 PM
DBGrif91
24
08-09-2013 05:08 PM
ahartley
07-22-2004 03:06 PM
tiap
07-02-2003 09:45 PM
Quick Reply: '96 F-150 5.8 EGR stumble / surge
