Looking at a unibody. Could use help
Hello Everyone,
I have found a 1961 f100 uni with a 6cyl 3 on the tree 2wd for 3500. The truck looks nice and seems to have many new parts. is there anything I should know while looking? I have never seen a uni before but am starting to like them more and more. also, are the bed floors wood?
Marc
Marc
Hello Everyone,
Marc
Marc
Soon we'll take over the world.
Glad to hear it Marc. Like the guys above said, rust is the major deal. If it has good bones you can do anything. Get yourself underneath it and look around the floors and rear of the cab especially.
Take a screwdriver with you. If you can poke it through any metal you are going to need welding and fab skills to fix it.
Surface rust is no sweat.
Good luck.
Marc
Typical places to find rust are:
Front cab support-crawl underneath and look where the bolt comes down through the floor and attaches to the pad on the frame. The stamped tapered box is the front cab support.
Torque Box- Look at the floor behind the seat bottom of the gas tank area. This is the front of the "TB". Look under the truck at the front of the bed area. This is the bottom of the "TB". Poke and bang around the bottom of the "TB". Soft spots and muffler rattle noise indicates rust.
Door pillar: Open the doors look where the botom hinges go into the cab.
Radiator Core Support: Look where the frame bolts go through on sides of the radiator, where the bottom of the grill attaches, and inside front of wheel wells
Cab cap seam/drip rails
Bottom corners of windshield
Hood leading edge
Hood leading edge
66 ford restore
12-17-2012 08:55 PM
The Incredible Sloth
05-21-2011 05:16 AM
