Ford reman HD4R100?
I went this way when mine went. Knew the service manager at the local dealership and he hooked me up with one installed for $2500. I havent had any problems yet. Have 41,000 miles on it right now. They do have a good warranty, not as good as BTS but pretty good. Have had no issues and I have a DP Tuner on my truck. Hope you have the same experience.
My thans seems to shift ok, my problem is if my Trans gets above 150 it pukes fluid out the front pump seal. Below 150 and it doesn't drip a drop at all perfectly dry. The Trans normally runs at aprox 130 butt summer is coming and my temps will be up a bit when it's 90 outside. My truck has 197000 miles and was told its the original Trans. My uneducated guess is that my days are numbered.
OK, I think I have an issue with my DP not playing well with my trans. 226k miles, original trans. It worked great, smooth, until I put the DP in. I love my DP Tuner, love it, but I need it to work nice with the trans.
Have you looked into the BTS? What is the price difference between HD and BTS?
I have the HD4R100, my 4R100 went all at once from stupidity (too much machismo, not enough mentality). It started slipping at a time when I didn't have a backup vehicle to wait for a JW or BTS. I know somebody who ate his first two HD4R100s, but Ford dialed the installation procedures to prevent this. It's not only a tranny, it's a prescribed parts list and configuration to extend the life of the transmission well beyond the original. My friend that ate two of them? He works at the dealership and plows snow in the winter. They learned altering the stock tune actually aids the life of the transmission.
I have the DP Tuner, and the dealership actually recommended getting the truck chipped - they install Superchips. My tunes first had issue with the dynamics of the HD4R100, and I felt like a couple of teenage boys were sitting behind me - kicking the seat back every time I shifted. I have the F6, so the emails were flying across the country for a short time (report to Jody, emailed tune from Jody). I can now say he nailed it. It's the best-tuned automatic transmission I've used in my life... and I've driven hundreds of vehicles. My wife loves the shifts, the only way we know it happened was the RPMs dropped and the accleration just keeps going. The shifts are not squishy, soft, or slippy - they're just solidly synchronized.
They knew about the DP-Tuner, but kept it on the down low. I only have one tow burn on my PCM, so I could get it reflashed if needed. My tranny went at 198,000 miles, just after moving back from Georgia, glad it didn't give out on the road.
If my memory serves me correct the JW is $4200 and the BTS is a little more, so still quite a difference from the Ford tranny. I wanted a BTS but it just wasn't in the cards at the time.
What dealership did you go to? If its not too far from me maybe I will check them out, my dealership is soooo against chips.
That is exactly what my trans feels like. To the OP, your leak sounds like a different story, you are probably right to be looking into this now before its too late.
I want those smooth shifts!!
If you have a PTO trans installed, then the high idle feature will work with a simple toggle switch. If you use an exhaust brake, then having a PTO trans is more beneficial than a standard unit. The TSS sensor is different on PTO models as well. Everything else is the same, a PTO trans can be installed in place of a non-PTO unit without any ill effect.
Here is a photo of a PTO trans access plate.
