2012 F250 Leaf Springs
I have a 2012 F250 with trailer tow, plow prep and the FX4 package. I had a load of dirt and the truck was squatting badly. I was getting my oil changed at the dealer and looked at other F250 without the FX4 package and they had 4 leaf springs. My truck has 3. The dealer couldn’t give me a reason why. Does anyone here know why? They did tell me I have the base leaf springs for load. That got lost in translation. Thanks for any input.
fficeffice" /><O></O>
szold
szold
Have added air springs (bags) and am thinking of adding an overload spring... or, maybe just get ahold of whole rear spring pack from a F-350... one of their 11200 or 11300 or 11500 spring packs... not sure what to do...
all the single tire rear springs are identical, regardless of package. The reason the other F250 had four springs is because he ordered his truck with the camper package that gave him the top overload spring. And that only hits when the truck squats bad, the reason your truck is squatting so bad is because some freaking idiot at Ford decided that the yuppies who buys these truck for just driving around town complained about the truck being rough so they designed the new springs to be so soft that a F150 can handle the same load now and not squat as much as these new Super Duties. Only thing you can do is get a spring shop to make you a extra spring, buy one from a lift kit company or add airbags to your truck. Its really sad that almost daily someone post on the same thing as you, my BRAND NEW SUPER DUTY CANT HOLD D%CK! All because a small group of people who buy them for the "look only" can make a TRUCK company redesign the main factor of a 3/4 and 1ton truck to such pitaful payload just to have a somewhat smooth ride..... very very sad
I'm a little confused by some of the comments here. I have dual add-a-leafs on each side of the rear along with Timbrens. They allow my truck to sit level with over 4000lbs of weight in the back. What confuses me is that before adding these enhancements, I could easily load 1000-1200 lbs in the back with very little, it any, squat (maybe and inch or so) which isn't bad given the level stance when empty. I'm a little skeptical of those who claim 700-800 lbs cause extreme squating. See my previous posts for references to enhancements and videos.
I don't know whether all your angry assumptions are correct, but if they are, then they did a great job as far as I'm concerned. I never expected an F250 to haul 17k worth of gooseneck and payload without squat. My buddy's old '01 F350 with the heavy hauler package (two complete spring packs for the old-school style lift) wouldn't squat at all, but it also rode like an empty dump truck and bucked like a bronco off road. I'll take civility and adjustability over steel-girder-like springs for the occasional/rare "just in case" overload scenario. No stock F250 should be expected to be a dedicated heavy hauler work truck. That's not what they're for, nor is that how they're sold.
I am looking at getting an add-a-leaf and Timbren SES. I noticed you have ProComp Add-A-Leafs... Where did you get them? I cannot find them anywhere. It looks to me like they only have 6"lift kits on-line. Any help is appreciated. Thanks.
Well, I just got my hide goose installation finished and hooked up to my wife's 4 horse slant horse trailer (10 ft living quarters) total length 33ft. Yes betty squated, but I was so impressed with her pulling (empty). My wife is going to pull tomorrow with a full load, I am so excited for her!! May look into some over loads later
This is the sag on mine with at least 1200 lbs. on it. Over 800lb atv with camping gear packed around it and the tongue weight of the trailer. Definitely squatting!
With only the atv in the back it drops exactly 1 inch. When I get some extra cash I want to install air bags to level it off.
this is the reason i tweaked my 2004 rear leaf springs, when i loaded my 2005 660 Grizzley into the bed the truck sagged about an inch or so and when i loaded my 16ft utility trailer with four quads to the hitch the truck was level. No way a 250/350 should sit that low with a 660lb atvin the bed and maybe another 600-800 pound tonque weight behind it. Most i ever had with the stock suspension was a load of cinder blocks and i think it was around 3600lbs, now my truck took the weight but my overloads were both touching and the rear was a good three inches lower than the front! My old 1997 F250 heavy duty carried the same load WAY better than my 04 so thats why i tweaked the rear to my likeing. Since ive had bed full's of fresh cut oak, cheery wood, topsoil, pallet of fresh sod, packing stone and the truck now sits level with almost 4k in the bed,the way Ford should have had the rear springsset up from the factory
there is a company within a few miles of my house (re pierson) they do all the roads in NJ. I talk to this one guy who does the framing for curbs and sidewalks. He just got a new 2012 F350 crew cab long bed CHASSIS truck, it came with seven springs in themain pack plus the top overload spring. He said this is by far the best truck he's had so far working for re pierson. Since he has a utility body on his F350 starting in 2008 his company switched to the chassis cab for all their utility body trucks but the regular work crew gets the standard F350 trucks and he said their payload stinks in nice words. You cant load the bed and pull his trailer without the back bumper almost dragging the ground. He says thats why his company is ordering so many new chassis cab F350 because the added factory rear springs makes it so much safer for the weight they haul EVER DAY
#28
How about a comparison picture with no load in the back and no trailer hooked up.
Now this is excessive squat.
#29
I put air bags on my 2005 SD within the first month of owning it. They are now one of the "must have" options for my truck. There are just too many variables in the loads I carry to expect a set of leaf springs to work ideally under all of the conditions. They making towing easier and safer, they should be an option from Ford.
#30
