4.9 np435/t18 swap - Page 2 - Ford Truck Enthusiasts Forums
4.9 np435/t18 swap
Old 05-08-2012, 06:49 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.
Originally Posted by ctubutis View Post
Any transfer case should bolt to any 4WD transmission.
I forget the two transfer cases used - BW1345 and an NP variant, I think.
NP208. And, this is one of the rare areas where Ford allows mix & match.
Old 05-08-2012, 06:55 PM
camo86
camo86 is offline
camo86 is starting off with a positive reputation.
okay thank you very much. oh and i am not sure if this means anything but does anybody know why people use the np205 transfer cases? are they just heavier duty?
Old 05-08-2012, 07:02 PM
camo86
camo86 is offline
oh and sorry about the mix up with words, didnt mean to throw you off i just didnt re-read what i typed
Old 05-08-2012, 07:08 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
You don't like research, do you? Here's the first link that showed up when I started typing "np208 vs NP205". Got "np208 vs np2" typed in and Google filled in the rest. Sure is easy to answer questions like that. (Hint, hint)
Old 05-08-2012, 07:11 PM
82f100460's Avatar
82f100460
82f100460 is offline
82f100460 is gaining momentum as a positive member of FTE.82f100460 is gaining momentum as a positive member of FTE.
The 205, and I think the 203, are gear driven vs chain driven. So yes, more heavy duty.
Old 05-08-2012, 07:14 PM
camo86
camo86 is offline
okay thanks
Old 06-09-2012, 09:55 AM
sabby101
sabby101 is offline
sabby101 is starting off with a positive reputation.
ok on the ford truck of that era the only thing you have to change when your going from a tremc to a t 18 or np is you take out the crossmemeber and youll see the bulge in the memeber all you do is flip it make the bulge face wawy from the motor everything else is the same the same output splines the same input splines speedo cable is the same the reverse light looks up the same im currently in the process from going from a t18 to a tremac rts ita the same procees but only reversed i figured with 800,000 miles on a that t18 its time to upgrade and com into the the club with overdrive
CantAffordAToyota
04-18-2017 04:36 AM
T_Cooksey88
03-10-2016 05:25 PM
T_Cooksey88
03-06-2016 11:46 AM
petrovich79f250
01-30-2014 12:14 AM
little_mule
1978 - 1996 Big Bronco
13
04-01-2011 10:38 AM
Quick Reply: 4.9 np435/t18 swap
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
