6.9 hard starts and lots of smoke! Help!
I recently bought a 4x4 6.9 from 1986. It's very hard to start, but when it does start it runs fine. I'm not familiar with these engines but it feels kind of weak on the throttle. As far as I can tell, it's getting fuel properly while cranking. It spits out white smoke that smells like unburnt fuel while cranking, and once started (on just a tiny hit of ether) it spits out a lot of gray smoke for a long time. The guy I bought it from said he couldn't find the 'y' on the IP gear, so he alligned it to the dot. I think that may be the problem, but it seems to run a little too well for the IP to be 180 off. I haven't had time for a compression test yet, but it kind of seems okay. Cranking speed seems fine, and all of the injectors are getting pressure. Whether warm or cold, it takes ether to start it if it is left to sit for five minutes or more. Should be able to get a compression test soon, I'll post the results to that, but in the mean time, I was wondering if anyone had any suggestions short of a new motor (Which I'm considering, seeing a buddy has offered me a 7.3IDI for $300.)
Thanks
Thanks
Have you checked the glow plugs? Have a read threw this thread https://www.ford-trucks.com/forums/9...old-style.html this will tell you all you need.
on
nice to buy from an honest seller,so you know whats up!
Thanks
Thanks
well,that's pretty hard to beat a good 7.3l for $300 bucks.however,you can likely fix the ol 6.9l for free.
here ya go;
"Talk about Timing!!"
and more tips:
https://www.ford-trucks.com/forums/1...pump-gear.html
here ya go;
and more tips:
TheDieselChick
19
06-30-2018 04:29 PM
guisepi
26
12-15-2013 12:27 AM
JamesHajek
74
01-29-2012 06:43 PM
yeldarb82
05-10-2009 06:03 PM
