1978 - 1996 Big Bronco
1995 tailgate replacement
Old 05-04-2012, 11:04 AM
areff's Avatar
areff
areff is offline
Exclamation 1995 tailgate replacement
Hello out there, I have a fairly simple question. I am looking to replace my 1995 ford bronco tailgate with a 1994 tailgate. I currently have electric w/w defroster, will everything still work properly?
Old 05-04-2012, 12:15 PM
AzPete's Avatar
AzPete
AzPete is offline
It should.....if the new gate has the same defroster setup.
I swapped gates on mine and both had defroster hookups. I had to swap the key switch because I did not have the key for the replacement. Not a hard task but it works a lot easier with two people.
Old 05-04-2012, 08:36 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
Be careful when releasing the torsion bar in the passenger side jamb. If the gate is almost fully closed when you remove the bolts that hold the "eye" in place in the jamb, it won't spring free abruptly.
The rest is a direct swap situation.
Old 05-07-2012, 05:15 PM
areff's Avatar
areff
areff is offline
Thanks for the advice I will have 2 individuals working on it.
Old 05-07-2012, 08:39 PM
AzPete's Avatar
AzPete
AzPete is offline
Since I was reusing a lot of the inside items, I removed all I was reusing from the gate before I removed it from the truck....then swapped gates and installed the glass and everything else. Less chance of breaking the glass in my opinion plus the gate is a lot lighter.
Stevem4134
1999 to 2016 Super Duty
18
06-28-2021 09:43 AM
roadtripdaddy
1997 - 2003 F150
12-07-2014 05:09 PM
jbegler
11-12-2012 07:38 AM
chad85
15
01-03-2009 07:43 PM
vooter61
11-21-2001 08:03 AM
Quick Reply: 1995 tailgate replacement
