Factory subwoofer upgrade?
#76
#77
#78
The dash is so easy to get out! And with the factory/aftermarket adapters and everything anymore, it's almost plug and play (depending on what you get of course)...
I dunno, sometime's it is easier to just pay someone, but then you're left dealing with what possible shortcuts they took. The "installers" that did my truck did such a terrible job I ended up redoing everything myself, along with adding a few extras.
#79
#80
You expect that they would be, but unless you're looking over their shoulder, you won't know what they did until you started running into problems. Trustworthy stereo places are few and far between in my neck of the woods, and I unfortunately found another one to add to the list... They gave me a smokin' deal on all my components and I have a warranty on all of it, but the work itself was just garbage. It just reinforced my opinion that if you want something done right, you gotta do it yourself.
It's fine though, I was able to freshen up my own install skills. My system's solid now, as I'm sure yours is, and in my opinion should've come from the factory sounding this good.
#81
#82
#83
I kept all my factory junk, it's going right back in the truck when the time comes to sell it.
#85
Thank you for pointing me in the right direction. Wasn't a hard install, just took a little time routing the wiring. Also took a little time finding the time for this timely install...now it's Miller time.
OK, I don't drink Miller but it sounded good.
#86
I have a subwoofer from my old 7.3 I took out when I sold it.Unfortunately the enclosure is too tall.I think I read through this post and someone intalled a ten inch subwoofer into the stock enclosure?My subwoofer is ten inches too.Would this work?Does the enclosure easily open up?Would it make a difference in sound just replacing the subwoofer?Im not putting a new amp in just replacing the sub if its feasible.Thanks for any insight.I dont want to waste my time if its not possible but I have it laying around if it is.
#87
#88
It wasn't pretty, but it did work. After taking a closer look at the factory Sub Amp, I doubt that just replacing the driver would make much difference. It's fed by 18 gauge wire so can't be pushing many watts. Pretty much have to pull the seat to do the driver so might as well do the amp at the same time.
#89
#90
