FINDING TDC?
Old 06-17-2012, 02:19 PM
chamblizi's Avatar
chamblizi
chamblizi is offline
FINDING TDC?
Hey how do i find top dead center i am changing my timing chain soon.
(SOLVED)
Old 06-18-2012, 06:14 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Ok, pull the valve cover & #1 spark plug.
place the tip of a finger in the spark plug hole to feel pressure or suction (if you are working by yourself, you can rig up a baloon to part of an old spark plug that screws into the hole too)
rotate crankshaft (with wrench) until you feel pressure stop & it starts to suck, look at valves, both exhaust & intake should be closed.
reverse rotate the crankshaft until it starts to suck again....when you feel the point that it does not suck or push air out, the piston is at top dead center, this will also allow you to verify if the timing marks on the crankshaft are correct/true.
Old 06-25-2012, 01:01 PM
Jippah's Avatar
Jippah
Jippah is offline
That is a very unique way of finding TDC.
I've always done it the hard way and removed the cylinder head to do a visual check :\
But that was on little SOHC 4 bangers
Old 07-04-2012, 08:47 PM
twosfamily's Avatar
twosfamily
twosfamily is offline
I like that balloon trick! I will have to try it sometime!
Old 05-19-2014, 09:20 AM
zombievan1966's Avatar
zombievan1966
zombievan1966 is offline
pull #1 plug.. pop cap off of dizzy. #1 tdcc will bee #1 piston all the way up.. the balancer mark lined up with the f mark on timing cover and the rotor bug facing the #1 termnal on the dizz cap...if your valve cover is off.. both valves should be opened and u should be able to wiggle the rockers a lil bit.
Arizona84F150
05-04-2017 10:03 PM
jpyles
11-09-2015 03:45 PM
Gil Chesterton
03-16-2006 02:14 PM
DT 466Man
16
10-02-2005 08:18 AM
rickm15752
11-12-2003 08:39 PM
Quick Reply: FINDING TDC?
