That FRX made a world of difference....
I rebuilt the fuel bowls on my Dad and I's trucks over the weekend. Big thanks to Bob for the o-rings and good instructions. The fuel bowl rebuild was simple! While I was into mine I installed that FRX I got from Clay months ago (I know, I procrastinate...)
The FRX install was a piece of cake with the fuel bowl out of the way. Only way I'd do it again. Fuel sleeves are too cheap not to do it this way. My fuel rail plugs came right out using a 5/16" square drive socket, wobble extension and ratchet. Only the front hose fitting gave me fits. I couldn't get my hands on it enough to thread it onto the fitting in the head. I was trying to do it from the front of the truck and it wasn't happening. Once I tried from the pass side leaning over the AC compressor I was able to thread it right on.
Anyway, the truck is much quieter and smoother. Thanks Clay.
Next on the list is glowplugs, sticks and a turbo (found the seals leak a bit)
I just finished mine too along with the HPx. I am not sure if it is any quieter yet but I haven't taken it out for a drive to make sure all the air is out of the system. I have the Early 99 though so I had to grind off some on the exhaust as noted. It wasn't to bad doing it with a Dremel. It makes me nervous having that fitting so close to the exhaust. Won't it really heat up the fuel being so close? Also as other have said, I am not sure why the rear line is so tight. I would think it should be about another inch longer so the line isn't pulled as tight. It is in the straightest line it can go and there is no other route it could take.
Everything else went fine, I hope no leaks develop.
As you can see in the picture, this is a much cleaning result than the sample picture shows with the instructions.
