1991 F150 won't start
My 1991 F150 won't start. Dual tanks, 2 fuel pumps. I can hear the fuel pumps run but don't get fuel to the intake. Fuel filter is clean. I can hear a vacuum leak near the intake where there is a small vacuum pump but can't pinpoint the leak. I'm not sure why neither fuel pump will get gas to the intake. Any suggestions?
I should add that this has been an intermittent problem but has gotten worse.
Provided there is fuel in each tank, for sure, then the next step would verify that you have a pressure reading, off each tank, at the fuel rail.
There is a vacuum operated fuel pressure regulator on the intake manifold, near the coupling of the fuel lines to the fuel rail, that sounds like it may be worth a look.
Thanks TB!
I would dough the FPR is the problem. The way they go bad most of the time is they leak fuel into the vacuum line going to the intake from the nipple on top of the FPR.
You more than likely have fuel pressure to start the engine so I would check to see if you have spark when it does not start.
If you have spark then I would change the PCM Computer.
Jbarth73
06-02-2015 08:14 PM
Dave13
07-11-2007 07:18 AM
BarnacleBob
09-12-2005 06:02 PM
