2006 6.0 smoking, some advice to my diagnosis?
Hey there, i know there is many threads out there, that are on a similar topic, but none are explained in the situation/symptoms i have
I have a 2006 f350 with 75k on it, has a mild sct towing tune, and 4' turbo abck dual exhaust. It recently started blowing whiteish smoke, so i did an EGR cooler and valve delete kit, and it stoppe dsmoking for a while.. coinsidence?
It has recently started again, at idle there is no smoke, and taking off slow from a stop, it doesnt ALWAYS smoke. but mleaving a dead stop, if i get right into it, it billows whiteish smoke, and if im cruising, romp on it, let off it, then get on it again it will smoke.
Ive been told fuel pressure, injectors, turbo seal etc. when i had the down pipe off, no sticky black residue was present, so im counting out turbo seal (for now). I purchased the blue spring upgrade for fuel pressure, because i was told its not getting the right amount of fuel, once i get that ill throw it in and see if it fixes it.
whats yall's opinion? is it worth have it checked for a failed injector? as i said, no EGR in the truck, no loss of coolant either, oil is clean. It does seem a little sluggish at times off the line now as well.
any ideas?
thanks in advance
any ideas?
thanks in advance
Welded a leaking cooler? I have a sinister diesel EGR cooler delete, and valve delete I ordered from mkm customs. So you guys don't think it's injectors? I'll have to look into a scanguage if the blue spring kit does not solve my troubles
on
before deleting the valve on your 06 please review the info found in this thread.
https://www.ford-trucks.com/forums/9...egr-valve.html
this info comes from testing on my personal truck by me and was confirmed by Matty as well
If that's the case I hope I still have my egr
I know it sucks if you threw the EGR Valve away but it needs it for that fan you dont want it to over heat
Odds are egr vave missing isnt causing your smoke thats from an Injector or a bad turbo seal
my 06 f350 started blowing black smoke
I've got an 06 f350 150k miles on it. About a month ago it puffed white smoke so I replaced egr valve. One month later it started blowing black smoke... My first guess was injectors... Took it in for diag and testing and all injectors have good compression. The mechanic is recommending a egr delete along with some other work. Is this neccasary? I have to pass emissions where I live so idk this is an option... Any input is appreciated!
Hawkeye2
1999 to 2016 Super Duty
04-17-2015 10:13 PM
villestrip
09-17-2010 12:32 AM
