It came with a 429. Although it needs a little putting together. The oilpan and intake are not on it right now or the water pump. He bought a new oilpan that would fit the bronco as well as a new water pump. I may just plop in a 400 for the time being.
So I'm looking up fuse panel diagrams for an 06 Expedition. Found a few, I might be able to show a Ford parts guy what I'm looking for. I have the relays I'm looking for, but need a "maxi fuse" that looks like no other maxi fuse I've ever seen.
Back to google images...
edit:
Turns out it's a Maxi Fuse female type. So now that I know what it is, I won't sound like a dumb *** at the parts store.
Pretty much the same old same old. Got the Bronco off the trailer this morning, returned the trailer, helped the fellow a the wreckers with a couple things, worked on taking out the kitchen cabinets.
Yep, just two of us closing. They sent a couple out to clean up the pipes of debris that I blew into piles. I don't even know if the greenhouse was cleaned. And still didn't get everything dome that I thought needed done.
