Was wondering if a 351M from a car is the same as a 351M from a truck. I read in one of the posts in this forum that the car and truck had different configurations for the oil pan.
Also, car blocks will not have the block off bolt for the front dipstick hole. You will have to block this off if you plan to use the motor with a rear sump oil pan.
Chris is correct on the reinforced main bearing walls on the truck blocks, but the 78-79 D8AE car blocks also received the reinforced main bearing walls as well.
