New shock and stering stab - Page 2 - Ford Truck Enthusiasts Forums
Old 05-04-2012, 04:14 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
Quote:
Originally Posted by ApriliaHauler View Post
I just got the same parts in yesterday. I was going to put the double kit in but was under the impression that was not possible unless you had at least a 2.5 level. I think EpicCowlick mentioned that his his video of the Rancho 9000 install. Can anyone confirm this? I would rather have the double but I cant do a level because of the garage.
From what I've seen, it seems to be application specific whether the double stab setup works with a factory setup. It works for some but not others. My truck is stock but will be doing a leveling kit at some point, so I opted to just replace the OEM stabilizer with a Bilstein 7100. Huge improvement over stock to say the least.
Old 05-04-2012, 04:37 PM
Michael53 Michael53 is offline
Michael53 is starting off with a positive reputation.
I can verify that the Rancho dual steering stabilizer does not work with a stock height F250 CC Short bed. I installed only to find out that compression of the suspension allows interference with the pan I believe- but forget specifically what would hit. This would then cause the dual mount to rub against the steering arm causing drag.
Mike
Old 05-04-2012, 05:06 PM
doublenot7 doublenot7 is offline
doublenot7 is gaining momentum as a positive member of FTE.doublenot7 is gaining momentum as a positive member of FTE.
I was told at 4 Wheel Parts when I ordered the stabilizer that the dual-kit would fit my standard height but it would require some cutting(?), I lost interest about that time so I have no more details.
Old 05-04-2012, 05:10 PM
SavageNFS's Avatar
SavageNFS SavageNFS is offline
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
Don't do it unless you have a leveling kit. Suspension will hit the stabilizer bracket at compression for sure. A single Rancho or Bilstein will do just fine unless you are really running the truck off road a lot. I am off road frequently and use the Bilstein 7100 and it does awesome. Not ok, awesome.
Old 05-04-2012, 05:26 PM
ApriliaHauler ApriliaHauler is offline
ApriliaHauler is starting off with a positive reputation.
Thanks for the replies, I'll just stick to the single. Im headed out to put everything on right now. Can't wait to see the difference.
Old 05-04-2012, 05:28 PM
SavageNFS's Avatar
Good luck and enjoy wrenching on your truck!
Old 05-05-2012, 06:39 PM
That was the advice I received also, stick with the single unless you will be off road alot or running 33's on the truck.
Old 05-05-2012, 08:23 PM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
I pulled the trigger as well for a set of 4 9000xl's and a steering damper. I was originally dead set on only purchasing the Bilsteins, but after talking to many people I was assured the REAL Rancho's were as good as the Bilstein's. I say real because the ones I'm replacing were the Ford OEM Rancho's. I will also admit the price was very right with the $100 rebate and Rancho is manufactured by Tenneco, which is 10 minutes from the house. It's always nice to support the local boys
Old 05-06-2012, 09:01 AM
porthole's Avatar
porthole porthole is offline
porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.
I'm having trouble finding rancho part numbers that match application and then match Amazon's listing. I wrote ranch last week for correct numbers for shocks and stabilizers. No answers yet.
Also inquired about the rebate being applied to 2 new shocks and the 2 new ranchos that came in my Tech R kit.
Rancho Shock (RS9000XL) Setting? RM2012F350 6.7L Power Stroke Diesel 35 12-21-2017 11:46 PM
Rancho RS9000XL mattymax 1999 to 2016 Super Duty 70 05-31-2017 02:00 AM
Best shock option. dusty trail Fifth Wheel & Gooseneck RV Towing 37 04-21-2016 02:22 PM
V/B Spring Rancho Rs9000XL Question aaedin Excursion - King of SUVs 5 12-08-2014 01:12 PM
Rancho 9000xl settings?? 05excursionred Excursion - King of SUVs 4 02-12-2011 11:44 PM
Tags
2012, 7100, bilstein, duty, explorer, f150, f250, ford, install, leveling, mount, noticeable, shocks, stabilizer, steering, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
