cam help
Old Apr 30, 2012 | 07:16 PM
funford77's Avatar
funford77
cam help
hey guys, im new to this site and could really use some advice on a cam for my .060 over flat tappet 289 with stock e7 heads, performer rpm intake and edelbrock 600 4 bbl. not trying to get alot of power just a good running motor with a lopy ( noticeable ) idle. thanks
Old Apr 30, 2012 | 10:03 PM
Blue and White's Avatar
Blue and White
What's that 289 in? Weight, gearing, tire size and planned use have a lot to do with cam selection.
Old Apr 30, 2012 | 10:05 PM
funford77's Avatar
funford77
77 f 150 lwb c6 not sure about gears yet and stock tires
Old Apr 30, 2012 | 10:12 PM
funford77's Avatar
funford77
it had a 302 roller block with 2 different truck heads, ( stupid ) i know but i got it that way, i was able to get a fresh 289 .060 over with the brand new intake and carb that i listed before for 200 bucks, going to put the e7 heads on and get a little bumpy cam for the sound and just cruise around in her.
Old Apr 30, 2012 | 11:05 PM
meborder's Avatar
meborder
a lopey cam, stock heads, and a 600cfm carb might not be a lot of fun to drive, especially in a truck.
don't get me wrong, i understand what you are after, but from my experience, a 600cfm carb is a lot with a stock head-ed SBF.
My advice:
Shoot for duration of 210-220* @0.05" lift, a 500cfm carb, spend some money 2000 or 2400rpm stall converter (depending on your rear gear), and enjoy the sound of all 4 barrels open at one time ... and forget about they way it sounds at idle.
If you are going to use a roller cam, you could probably shade a little higher on the duration, but if you get a long enough duration that the engine lopes, you may find that your truck is a lot less fun to cruise with, unless you go pretty deep with the gearing, and go with a pretty high stall converter ... all of which can get old on the street.
Shoot for a cam that will give you about 80% of your max torque from about 2000 rpm to about 5500rpm, and it will feel like a freight train when you lean into it.
my $0.02
Old May 1, 2012 | 05:32 AM
Blue and White
Agree you do not want a big cam... big cam and heavy vehicle makes no fun. One thing to check out are Comp Cams "Thumper" series. They are made to produce a noticable idle but smooth out with a little RPM and produce good mid range torque. One of the smaller Thumper's may fit the bill for you.
Old May 1, 2012 | 10:32 AM
PEARLOFTHEDESERT's Avatar
PEARLOFTHEDESERT
Hey all, I've been looking at Lunati high efficiency camshafts for a 460 with no mods on the engine. anyone try one of these? What would be a good cam for this engine??
Old May 1, 2012 | 10:03 PM
funford77's Avatar
funford77
thanks for the advice guys, i will be in touch.
1966Tbird
Aug 11, 2009 04:39 PM
dieselburner6.0
21
Mar 23, 2009 10:47 PM
thunderguns71
13
May 20, 2004 09:59 PM
srm148
Sep 20, 2003 04:16 PM
TrackStar
Mar 14, 2003 03:51 PM
