1978 f600 dump truck
Is there a brand name on the hoist?
You may have to search around on it, scrape some crud etc.
Now while you are doing that, be sure you have TWO sturdy supports under that bed. And someone standing by to warn you of any movement while you are under it.
The mortuary charges extra to re-inflate you after you are crushed, and there is a hydraulic oil removal surcharge as well.
i will get to scraping and see what I can find.
I'll also head your advice... pretty sure I cannot squat the dump bed lol
Hey ... check me on my thinking here... If one cylinder is leaking pretty good then it would seem to me that its the other cylinder holding up the bed. If i'm hauling light material... could I shut off fluid to the leaky one and let the one cylinder do the lifting?
As for repair, you can search by the brand and "parts" or "repairs" and find:
http://www.maxxhyd.com/seal_kits.htm
http://www.xtremecylinders.com/hydra...USA80770/5669/
markusselanne
10-03-2011 09:24 AM
rcav8or
01-30-2008 06:52 PM
