Excursion Roof Paint Cracking and Lifting
I happened to look at the top of my 04 Excursion yesterday and found the paint cracking and lifting off the roof. So the first thing I did was to come look here and see if it was a common issue. I searched and found a couple threads about this issue from 2 and 4 years ago. Apparently, the paint was applied too thick and that is why it cracks, lifts and breaks off. Some said they went to ford and ford has offered some type of discount on the repair.
But, that was years ago and I'm not sure if I think that ford is liable to fix this on an 8 year old vehicle.
Has anyone else had this problem with their Ex?
I uploaded a couple pictures of the spots.
Ford Truck Enthusiasts Forums - wikdwest's Album: Roof Paint Cracking - Picture
The reason I was looking at the roof is because I just got some crossbars because mine didn't have any when i bought it.
I had the same thing and had to leave it with the dealer for a while and raise heck, but they did fix it under the ESP warranty last year...twice! I'm sure the cruddy job will require another repaint, meanwhile I've got star marks in the hood that will need addressing soon!
I was quoted around $750 for the roof stripped and repainted by a great shop.
Roof Repair
I got 2 estimates to fix the roof:
The first place, a local body shop been in business 40 years quoted $2496 to fix the roof. Out of curiosity I asked what it would cost to repaint entire vehicle and he estimated about 7K.
The second place, Maaco quoted me $1220 to fix the roof. The cost to repaint the entire vehicle about 2K for their 2 stage paint. He also told me that I had some hail damage from last year on top so I should call my insurance company and tell them I had hail damage which caused the paint to crack and peel and now rust.
I don't want to throw that kind of money at fixing the roof and I don't think insurance will pay up so I think I will look into using bed liner up top.
Anyone know what kind of prep work I need to do for the bed liner? Obviously I need to go down to bare metal where the rust is and primer those spots, do I need to scuff the paint everywhere else that I'm going to apply the bed liner?
All input and suggestions are welcome. Thanks
I'd suggest that stuff. Use a sanding disc to remove all the current rust you have and scuff up the paint all over the entire roof that isn't rusting/damaged.
Whatever product you use for paint, I'd avoid personally the bedliner stuff that is textured. Non-textured should be fine. If you have textured, it will have lots of dips and low spaces where water can collect. Then the water can start working it's way through the top coat and begin the whole process anew
Thanks
I was quoted around $750 for the roof stripped and repainted by a great shop.[/QUOTE]
My 2000 has 4 paint peeling spots w/light rust under them. I was quoted $400 to scrape,seal,paint and clear. My truck is black with gold trim and roof. I think my quote is a great deal after reading others.
