2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 Expy Rear Differential Friction Modifier?
Old 04-30-2012, 09:11 PM
dgruhlke's Avatar
dgruhlke
dgruhlke is offline
Hello-
I just changed the rear differential fluid in my 2007 Expedition. From what I can tell the 2007s and newer do NOT have limited slip differentials, they have traction control. When the truck is jacked up and I spin a tire one way, the opposite tire spins the other way. Per the manual, the friction modifier is only needed on models with the limited slip. This is a bit confusing since it's not offered I don't know why they put that in the manual... but my question is am I right about this that I don't need the friction modifier?
Thanks!
Old 04-30-2012, 09:35 PM
critterf1's Avatar
critterf1
critterf1 is offline
Should not be needed.
Old 05-01-2012, 10:23 AM
berry1234's Avatar
berry1234
berry1234 is offline
Whats the manual say? If it says add it I would.
Old 05-01-2012, 11:22 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
No LS in the 07+ Expy
Just put the spec'd dif fluid. No modifier needed
kbwford
1997-2006 Expedition & Navigator
11-08-2016 11:00 AM
ajonesnv
09-03-2013 03:26 PM
wameyer
19
10-30-2012 06:07 AM
tazf250
1978 - 1996 Big Bronco
11-22-2009 04:04 PM
Warfarin
05-16-2008 09:59 AM
Quick Reply: 2007 Expy Rear Differential Friction Modifier?
