Degas bottle - Tee kit - on Warranty Hist - where is it?
Hey everyone - I recently bought an '08 F350 Lariat crew cab dually - bought it via ebay from lot that deals strictly in HD trucks (mostly coming from repo/auction) - had 97k on the dial and got it for $23.5k - it is super clean and I absolutely love it so far. Had a Ram 1500 but it just wouldn't cut it pulling my new big camper. Now I have diesel fever and can't wait to do the exhaust and tune it.
Anyway - I finally got the OASIS and warranty history and the only thing on there is a T-kit that was done at the dealer before the sale to the original owner. However, when I look at my degas bottle, there is only one fitting on it and it isn't attached to what my research indicates to be the tee kit related to the service bulletin.
Did this actually not get put on? Do I have a different degas bottle that wasn't subject to the bulletin but the put it in the history anyway?
Here's a pic of my degas bottle and a pic I found of one with the Tee installed (mines actually the bottom one).
Thanks for your learned opinions and insight!
I'm hoping the discoloration of the degas bottle is just from normal hose wear/breakdown and not something more serious.
*actually it's about 3/4 of the way to the top of the cold fill 'range', about 1/4" below the top of the cold fill range. Mopping around in the black stuff in there it seems 'rubbery' or 'sticky'
Thanks for the answer
Well not to rattle your nerves but I don't think your oasis is up to date. That degas bottle was not out when that truck was built. Only the venturi T to the best of my knowledge.
So that means there has been either a radiator or maybe a t stat failure or something.
Which is ok..it has been repaired and that is what you want.
But the color that I am seeing is a concern. I bet if you check the nitrates they will be non existent.
I think that if you got any warranty or anything or even out of pocket I would do the coolant flush on it.
I've already taken it on a couple of 100 mile trips and hauled my camper on one of those since I got it and have another planned for Sat. Is doing the flush something I need to do before the trip? OK, maybe you do have me a little rattled
Take it in for the 11B23 recall. That is an update flash for the pcm. It is able to detect issues better than the current flash.
Coolant flush is non warranty. Nitrates will slowly degrade over time. There is nothing you can do except recharge the nitrates. In your case a flush appears to be warranted.
The right chemical balance assists with corrison and cavitation so very important.
Dealer maybe expense but if you have a quick lane in town try them...they are still ford.
The quicklane cannot do the flash though.
98x50
06-26-2011 09:36 PM
