Just make sure you get a complete set, as reportedly they're not an exact match to the originals (unless you don't mind that they won't all match).
At this point I havent found no good door panels in tan or for a crew cab in decent shape, they do come in pairs there also a complete set with front door panels and dash board cover.
You beat me to it, it has reverse thread, so it don't come loose when the truck is running
Hard to find a wrench that fits in there......
I had a wrench that was made from plate for another pump so I drilled a hole in some 1/8" plate and locked the pump to loosen the fan. SOMEONE got it good and tight before trying to loosen it.
Anyhow full steam ahead. I should probably find the special fittings and plan to put in that new filter water pump.
Lefty loosie, righty tighty use an air chisel if you have one or just rent the right tool from your parts store Nate.
The parts stores here may make most if you chuckle. I can buy a plasma cutter and tig welder no problem but rent a tool?! Nope. I made the tools with the bigger tools!
It's all done, noodle head here was trying to get it extra tight.
I rented the tool but had to straighten it out to make it work, normal threads on my fan but the big warning label of right hand thread make people doubt themselves and try it lefty
