A very strage no start
Well my truck left me stranded at a park today. Hop in, key goes in the ignition, truck powers up but will not start. Run to auto zone and get a new lock cylinder and same problem, key turns all the way but no start, also truck will no longer power down, even with the key cylinder removed the truck stays on.
I will be disconnecting the chip in the AM however after that I am stumped
Any recommendations?
It's definitely the mechanism after the ignition cylinder as a new replacement cylinder functions the same as the original. The strange part is the truck cannot be turned off ( engine not running ) I had to disconnect the batteries . The dash powers up as normal but can't remember if I got a WTS light
Ok just came in from working on truck, it continues to not crank. More info:
Chip has been removed
Tach sweeps and WTS light is coming on
No codes
OD light turns on if I push the button
As soon as the batteries are hooked up the dash/lights turn on even with the ignition cylinder removed
Wheres the switch on column and what am I checking for there??
No codes
I don't know if the ford mounts are kinda the same as Chevy switches on the steering column. But on the chevys. the switch has a slotted holes to adjust the electric switch position. if the screws come lose on the electric switch, it will move up the column and the rod from the key-switch will not pull or push the electrical switch to the right position
