Front visor mount question
Old Apr 22, 2012 | 12:28 PM
427 fordman's Avatar
427 fordman
My front visor has a screw that won't tighten up all the way, ie stripped out. I have to reach out my window every 30 miles or so and tighted it up with my fingers to keep it from making noise. Can't find a bigger screw. Is there some kind of insert or something I can do with the hole to make it smaller (without welding) so it will stay tight?
Any ideas welcome. Maybe I should know, but I don't.
Old Apr 22, 2012 | 12:32 PM
ReBilld's Avatar
ReBilld
Put a big pop rivet in it.
Old Apr 22, 2012 | 12:59 PM
fordpride's Avatar
fordpride
Maybe a Sheetrock insert.
Old Apr 22, 2012 | 01:54 PM
fordman67's Avatar
fordman67
we have a tool at the shop that has these inserts.There is a tool that the insert threads on to then is inserted into the hole and pull the handle.That expands the insert and sets it and wala,nice new threads,machine thread,many sizes.You should be able to get them from any auto body supply house.VERY helpful for many uses! We use them alot in fiberglass street rods.
Old Apr 22, 2012 | 02:10 PM
ReBilld's Avatar
ReBilld
That would be the way to go right there.
Old Apr 22, 2012 | 06:11 PM
427 fordman
Thanks fordman. I may try an easy way like Mike said, but am glad to hear there is a proper fix. reps.
Old Apr 22, 2012 | 09:06 PM
444dieselrod's Avatar
444dieselrod
On both my '97 and '96 the center bolts right above the windshield stripped out, I drilled through BOTH layers of the roof and put a long bolt through it from inside the cab. Had to pull the head liner down, and took a second person to tighten it but it never loosen up again.
Diese Rod
Old Apr 22, 2012 | 09:08 PM
fordman67's Avatar
fordman67
Hey,NO problem. I am thinking it is something like thread setter or similar.
We use it for all kinds of stuff. Electric trunk lifter to deck lid,interior trim panels etc. Very usefull. Even exterior mirrors....
filthy6
Jul 13, 2015 11:57 AM
9.ford.5
Paint & Bodywork
Apr 2, 2009 01:34 AM
NH-Hottie
1978 - 1996 Big Bronco
May 3, 2004 04:58 PM
tlb
Mar 7, 2004 03:30 PM
Rockwell
Paint & Bodywork
Jan 15, 2003 08:14 AM
