Power Steering issues '72 F100 w 390
My 17 year daughter recently bought a '72 F100 with a 390.
There have been a few things that needed fixing on it - battery was dead, carb needed cleaning, filters, etc. The major issue is that the power steering pump keeps throwing belts. I've watched it enough to know the belts twist up just before coming off.
It looks like someone replaced the pump in the not so distant past, but mangled up the pulley. I can find rebuilt pumps all day around here, but no one seems to know where I can find the pulley.
The parts breakout on fordification.com shows the part number for the pump as 3A674 and the pulley as 3A733. I also need the dipstick, 3A006.
Anyone have any suggestions, or thoughts?
The parts breakout on fordification.com shows the basic part number for the pump as 3A674 and the basic part number for the pulley as 3A733. I also need the dipstick, basic part number 3A006.
Does this truck have A/C and/or dual belt alternator? If not:
C7AZ-3A733-E .. P/S Pump Pulley-Single Sheave-4 5/8" O/A diameter / Marked: 6AA / Obsolete
Applications: 1968/72 F100/350 360/390 without A/C or dual belt alternator / Misc. 1967/72 Ford/Merc Passenger Cars / 1 available NOS
D6AZ-3A006-B (replaced C7AZ-3A006-C & D1VY-3A006-A) .. P/S Pump Dipstick / Obsolete
Applications: Myriad 1967/77 FoMoCo vehicles (1978 and later is not the same!) / 42 available NOS
Make SURE the rebuilt P/S pump you buy has a STEEL reservoir. 1978: FoMoCo changed the P/S pump, has a PLASTIC reservoir.
The P/S pump pulley has to be pressed off/on. Clueless previous owner was unaware, mangled it to death, prolly beating on it with a hammer. Didn't do the P/S pump any good, either. Wouldn't be surprised if it leaks like a sieve.
The 1964/72 Ford Truck Parts Catalog is available on a CD from hipoparts.com. The basic part numbers you found in the illustration section, came from this catalog. It's the same version that Fordification is using.
Brownievk
09-29-2017 08:23 AM
henryfrick
05-22-2016 05:26 PM
Marky48170
08-15-2011 04:27 PM
