Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
01 excursion cuts out while drive and starts surging
Old 04-18-2012, 04:21 PM
bigfordandjeep's Avatar
bigfordandjeep
bigfordandjeep is offline
bigfordandjeep is starting off with a positive reputation.
Its the wifes car so it hardly ever does it to me. Driving down the road and all of a sudden there is no pedal and the idle is really low and surging. Pull the car over, turn it off and restart it and its back to normal for a day or so. Having already replaced the icp sensor and cam sensor within the last 8 months for different issues which were resolved i went with a new pedal assembly. Not the problem. I am leaning towards dropping tank and pulling screens from pickup tube. Before I pull tank input would be nice. Thanks!
Old 04-18-2012, 04:42 PM
bigfordandjeep
More info. Never any codes, have ids at work. Only mods are exhaust, air filter and edge ez.
Old 04-18-2012, 08:16 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
diesel-fitter-bum01 is offline
diesel-fitter-bum01 has a good reputation on FTE.diesel-fitter-bum01 has a good reputation on FTE.
it won't run if you don't have fuel psi. Maybe you have a uvch coming loose. Does it some or have injector knock when it does this? Or does it shut off n turn back on again,like if you did it with the ignition key?
Old 04-18-2012, 09:18 PM
bigfordandjeep
Not sure what uvch is. It doesn't die or have any knocks. You are driving and petal just stops working and the engine is running at low idle surging. You pullover and turn key off and restart and it's back to normal running.
Old 04-18-2012, 09:38 PM
diesel-fitter-bum01
Uvch-under valve cover harness
They work themselves loose. Is there a chip in it? Could have a bad connection.
Old 04-19-2012, 01:25 AM
BigTruk small feet
BigTruk small feet is offline
BigTruk small feet is starting off with a positive reputation.
Thanks for clearing the abbreviation uvch up....lolol I also had no idea. Being new to the site the abbreviations tossed around here can be very intimidating.
Old 04-19-2012, 05:31 AM
diesel-fitter-bum01
Sorry,just get used to typing them.
Old 04-19-2012, 05:40 AM
Tugly's Avatar
Tugly
Tugly is offline
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
I would start be pulling that Edge "tunner" in your sig . You need to isolate whether the problem is mod or truck.
Is it possible you are overlooking any other mods like tail lights or stereo?
Old 04-19-2012, 09:05 AM
bigfordandjeep
The edge ez isn't a tunner and pulling it has no effect on the issue have tried that. It just plugs inline with icp sensor like a 10k mod.
Old 04-19-2012, 09:29 AM
Tugly's Avatar
Tugly
Tugly is offline
Woops.... I see I got mixed up. Wrong vehicle. I didn't know what an Edge EZ was, I just saw "Edge" and "Tuner", then I thought "Pull" - natural progression.
There's mention of rough running in this [LINK]
Old 04-21-2012, 07:13 PM
bigfordandjeep
Pulled a cam senser code today. Its only 6-8 months old, could it have caused all this?
Old 04-22-2012, 08:10 PM
diesel-fitter-bum01
Possibly I have bought bad ones right from the store.
RED DYE
09-10-2015 05:21 PM
Flatbed
02-02-2015 05:07 PM
Restlesswildman
05-19-2014 04:46 PM
Ariela
04-08-2014 10:20 PM
Ford Breakdown
Ranger & B-Series
18
11-04-2013 05:03 PM
Quick Reply: 01 excursion cuts out while drive and starts surging
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
