Fuel pickup and pre-pump filter installation photos, 99 F350 w/ steel tank
Spent a few hours yesterday installing a fuel tank pickup / pre-pump filter kit in my 99 F350. I ran into some minor snags and wanted to share how I worked around them.
The truck is a DRW cab-chassis with a steel tank:
The factory fuel supply hose was kinked and missing the protective loom:
After disconnecting the fuel lines, the pickup assembly was removed by unbolting the flange (no lock ring):
The factory depth of the pickup umbrella was measured, and the new fuel return and pickups were installed:
Here is the modified pickup ready to be re-installed in the tank:
First snag, the new fuel return line was a little too long and hit the inside of the tank:
That was fixed with a tubing cutter:
Second snag, the frame rail was about 1/2 inch taller than the supplied filter mounting bracket. That was fixed with some uni-strut and a beam clamp:
I haven't done any extensive driving yet, but on a quick trip the engine is noticeably quieter and the fuel pump doesn't sound like a straw sucking soda any more.
Chris
Chris
lafermedavid
09-29-2018 07:51 PM
Holehawgg
71
03-03-2015 09:08 AM
