Need to completley redo the rear brakes on my truck, I'm considering swapping to disc, did the trucks ever come with disc before they went to the metric bp? Can the stuff from the metric years swap over and I use. Non metric disc?
All the OBS trucks use rear drums. IMO if you get everything working properly on your drum brakes, they're fine.
The 99-up trucks are notorious for warped rotors.
yes the D80 did to bad they have 10 lug rims. also the van use 8x6.5 and started with discs i wanna say 98, the same time the super duties came out. I have the kit from blackbird I like it now i just need to find a hydroboost set up.
im aware that the vans had it (im runng a e350 rear in my Cherokee)but there a d60 with d70 outers so it wouldnt work with the 10.25,looks like the drums will be the best choice, thanks guys
i was just thinking for the rotors. though someone on some forum used a van axle and cut the brackets off and welded them to the sterling and then ran all the van things. to much work but it has been done.
just giving information
i was thinkin the same for the rotors, just misread your post
Agreed. As long as the shoes are adjust properly, I have yet to be in any 3/4-1ton truck that will out stop my 4 OBS F350s
