Steering has me pissed off. Bronco is dangerous to drive... please read
#46
Guys you have no idea how glad I am to have gotten this fixed. About 4 hours after I got the bushings installed some stupid $#@! tried to drive his Aveo under my Bronco!!! I was crusing at 75-80mph down I-270 with an orang Aveo directly beside me when this jackass decided they needed the exit we were passing! With no warning what so ever this tiny little car vears to the right heading stright at me!!!! Let me tell you, I alos had over 1000 pounds of tools in the back. Before i couldnt have avoided most likely running sead tiny car over. But I got in the breakes HARD swerved to the sholder and mannaged to avoid smashing this a@#h*&e or my truck. Missed that car by less than an inch!! True story. On a diffrent note. I am planning on up grading to the red head steering box as soon as funds alow!
You CAN adjust the factory steering boxes to tighten up the play. There is a large nut with a threaded rod sticking through it on the top of the box. Loosen the nut and turn the bolt in (some require a large flat blade screwdriver, others require an allen) 1/2 a turn until it's tight without binding. This little trick has SOLVED a LOT of issues we've had in the vans.
I tend to majorly agree with Encho. My own experience in "adjusting" those things always makes things worse, and others in 80-86 say the same thing.
Sure, you may reduce "free play" to some extent, but there is also the very real probability of losing the "feel" of the road as well as the ability for the steering wheel to return to center after a turn.
IMHO half a turn is a LOT, most guys in 80-86 will say 1/8th of a turn at a time, and also make marks so it can be un-adjusted and put back how it was.
#47
Steering gear
My experience..I tried 1/8 then added another 1/8. We were on a trip then the wheel started needing more effort to steer back to center. I got a kidney stone five hours from home and the wife drove us home. Believe me, nothing less than a kidney stone would have let me tolerate the wheel jerking from one position to the next with her.
I ordered a Red Head the next week and resisted the temptation to adjust it when it was too tight initially. It broke in perfectly.
#48
#49
#50
fishindave11
1978 - 1996 Big Bronco
03-07-2012 11:13 PM
Chevy Guy
17
06-18-2004 12:12 AM
