1978 F150 4X2 gas to IDI
If I didnt go turbo the only thing that would need to be modified would be the floor for the E4OD, If using the C6 no mod's needed...But I want to take full advantage of the Diesels fuel mileage.
Turbo mods to the floor on the passenger side, This corner needs to be bent in about 1 1/2 to 2" to clear up and down pipes
Here is the finished dented fire wall...16" from the gas pedal hole to the air box
This spot needs about a 1/4 inch removed to fit the gear reduction starter, And the dot is for the ETG probe about a half moon of a nickel
The Ford HI starter is way too big, And the motor being reversed makes for nice steering clearance
Heres my pan was going to just notch but would of only had 2-2 1/2 inch sump not enough for all the trouble so its raised about 1 1/2" and the back indention was flattened as well as some of the front to add back some lost capacity.
Drivers side engine mount all welded up and bolted in
Passenger side all mounted up
PS box has about 1 1/2 inches ended up better then I expected
Oil pan finished up...I know the weld looks like s**t but chasing down leaks was
You can see here why I had to trim the frame a little has good clearance now.
Transmission cross member was lowered 1" to clear floor
Front of the oil pan to frame cross member
Hope to have it up and running this weekend if all goes right.
I think it looks pretty good on there fills the engine bay...I dont think I'll be able to inter cool it theres very little room in from of my radiator....
#29
Very nice build! I like the 70's Ford chassis. They are quite unique and have a no-nonsense, all work look to them. It's too bad Ford didn't start offering Diesels in the 70's.
The Hypermax kits use the stock air filter. There is an adapter that fits under the air pan.
I'll get a picture of the Hypermax air intake, Probally the second most expensive part of the kit....It would be nice if was an option but the CDR hooks to it makes for a clean install.
So I did my last part of the install...Removed the 78 brake booster and modified the stock bracket and used the 91 brake booster, WOW talk about stopping power! Dam thing will stop on a dime and pick it up!!
