"HEPL"i need a ball joint part number
i have a 96 ford f250 4x4 7.3 that i started changing ball joints on today. i've been to NAPA, advanced and autozone and can not find upper ball joints, the ball joints in mine have no splinds, all the ones i can find so far do. can anyone please help me with a part number or tell me where to get the ones i need.
IIRC the lower ball joints are tied to the weight rating of the front end. Check the label on the driver door for the rated capacity. Of the top of my head I could be incorrect.
Motorcraft shows Part Number: 3V049 (MCS-10339) for the upper.
Part Description: 4X4 (Front)
Not sure if this pic is accurate.
on
f250 4wd w/D50
Federal Mogul - Moog Upper & Lower Ball Joints #K80026/#K8435
Federal Mogul - Moog Inner Tie Rods
#DS1072/#DS1069
Federal Mogul - Moog Outer Tie Rods
#ES2728L/#ES2727R
don't waste your time on the job by putting in something found at autozone.buy something with a good rep,or you'll be back in there in short order.junk parts,tires,fuel economy,alignments after the job,and your time doing it all costs $.try and make it count the first time saves big $.
#DS1072/#DS1069
#ES2728L/#ES2727R
