Help with 1993 Power steering pump pully
i Just had to put in a new power steering pump and i also bought a new pully for it. i got the pump installed and the pully about halfway on but i can't get it on any more and it's nowhere near aligned to the other pullys. it's on where you put it on part way then screw a bolt into the shaft then tighten a nut up to it to push it on i got it as far as i can but it won't move and more even with a air socket.
does anyone have some ideas of how to fix it?
the old pully i had to break it to get the pump off because i can't fit any of the 5 pullers i have in there i was turning the nut but now it won't turn any more. and since i can't get a puller in there to pull it off and try again i go to find a way to just get it to go the little bit more
[updated:LAST EDITED ON 12-Oct-02 AT 06:34 PM (EST)]They make a puller/installer just for power steering pump pullies. My advice would be to get one of those. I believe most parts stores will rent one to you. I bought mine for about 75 dollars. Good luck
ONLY LITTLE BOYS WEAR BOW TIES
Bill W
04-21-2017 05:48 PM
kyle j
02-05-2017 06:43 PM
dustinsheeler717
04-19-2015 09:35 AM
