Air conditioner clutch question
Hey all,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I have a 2007 f250 powerstroke with a dodge 12v and dodge ac compressor utilizing ford pressure switches. My ac clutch in not engaging and I am not getting power to it. So far I determined I have 12v to the low pressure switch. I don’t understand how the high pressure switch works but I have 12 volts on two of the four terminals. From there I am not getting voltage to my compressor wires. On the compressor I know I have a good ground to one wire but no voltage to the other. Is there a way to test the high pressure switch or is there another problem I am not seeing. Thanks for any help. Any test suggestions would be welcomed.<o></o>
I just put the system back together and vacuum evacuated it, added 9 ounces of oil and 2.8 pounds of Freon. The pressure is about 100 psi high and low side at 82 degrees F ambient.<o></o>
<o></o>
<o></o>
The high pressure switch is dual function, one being high pressure cutout and two being fan control. The high pressure cutout side opens at 435-475 and closes at 230-290 psi, circuits RD/YE and TN/RD. Circuits VT and BK/YE are fan control, if I rcall the contact closes at approx 325-350 can't find the spec on this one. Is this manual or automatic climate control.
The high-side switch is a safety cutout in the event of over-pressure. In normal operation, the normally closed switch contacts just pass the AC Demand/Request signal through to the rest of the circuit. When the system over-pressurizes, those contacts open to disable the clutch while simultaneously closing the other set of contacts to force fan operation (on vehicles with electric fans).
