Anyone add an inverter?
I have an 1800 watt inverter in my toyhauler, and pulling 1200-1500 watts from it will suck down my dual 6 Volt batteries in a hurry. It will run the microwave for a couple of minutes so I don't have to start the genny, but not for 10+ minutes.
I don't think you'll save anything idling the engine to run a large inverter in a truck - save your money on the inverter and buy a little Honda 2000i generator.
Yup, pretty cool too. 3000 watts of power and never an injector or ficm repair. But hey, it is only 2.4 HP and maybe 3 flbft of torque eh. I love to listen to it pumping out the power whilst by the campfire. And if the power goes out, I can still fungus tv, sat box, fridge, stove, lights and a blender.
Me too
I'm about to do this in my truck. Didn't know there was a factory option (mine is 2005 lariat) but it sounds like the factory inverter is under powered anyways. I have a 1000 watt TrippLite inverter that I've been schlepping around for a project just like this.
So Far I've decided the following:
1- Will be mounted under rear Crew seats (front are power and my inverter won't fit under there.
2- Going to run 6ga wire with a circuit breaker in-line from the battery to the rear along the frame. There is a rubber grommet entry point going into the cab right where inverter will go.
3- Going to run an on/off switch to one of the upfitters
4- Going to put 4 outlets in the center console: 2 facing the back and 2 facing front.
5- going to wire in a weatherproof box into truck bed so I can run stuff outside
Someone mentioned using the chassis as ground for the inverter. I wanted to do that because, well heavy gauge wire can be expensive. Everything I have read on wiring inverters though has been explicit that a negative needs to come straight from the battery. Something about chassis ground not being true ground and double grounding. Can anyone clarify this point?
Received 3,991 Likes
on
Remember, "Save a dollar.....Then spend $10".
on
Are you trying to say, you "Inverter" is useless, and you didn't warn her
on
on
Well, I think I'll stick with my wimpy portable one because it really does do all I need but I do want to say thanks to you all. I was feeling like maybe I'd missed a really great option but now I don't feel bad at all.
And every time I park next to my fence and have to slide out the door on the other side, I'll be glad I don't have that inverter (and center console).
#28
#30
on
It's kind of like if you had a building electrical circuit installed using EMT or RMC conduit - that's metallic pipe - from a 'does it work' standpoint you could probably use the pipe itself as the ground and neutral (both should be bonded together somewhere) and then just run a single hot wire through the pipe... but then the pipe and all the boxes would be current carrying. And of course it's not code compliant.
