did my fuel pump go out???
I haven't had a chance to look yet, it's storming like crazy here.
But yes, the pump started making a funny whining noise a few months ago. And it's wasn't a continous noise either....it would cut in and out like it had a short or something. But I checked the wires. And since it was starting ok and running fine, I didn't replace it.
When it quit on the way home and I was waiting on the person that was gonna tow me home, I tried the key a few times and the pump isn't making the noise anymore.
A simple band clamp holds the pump to the frame, but you'll need the tool for the fuel line. It's a cheap plastic tool that can be found at any parts store. It's either the light blue or grey one I cant remember....
I turned the drain and a little bit dribbled out. I closed it, turned the key on for about 10 seconds and opened the drain again and nothing came out. So it's prob the pump right?
I could hear the vacuum pump making a noise too.
I've tried to get the fuel pump off and I cannot figure out how to get the damn thing off.
Mine has been modded so Looking wont help... IIRC the tool is used on the rear with the black umbrella connection, I cant recall what the front looked like. I'm trying to find pics for you.
#28
Actually I got it off. Like I said, the front just unscrewed, but the back had sort of white clip that you pull apart a little and it slips off and then the linejust pulls off. Does this sound right?
And also, do you think it's the pump? When I took the front line off I turned the key on for a second or two and nothing happened.
#29
#30
