1998 ranger 4x4 trans problem
05-06-2011, 10:32 PM
on
my 98 4x4 with a 4.0L auto trans wont go into gear when i put it in forward or reverse ? the truck ran fine and it just wend out .
05-06-2011, 11:30 PM
on
If everything shifts fine as far as when its driving then youll have to check you shifting linkage from the dash to the tranny
05-06-2011, 11:48 PM
on
at a stop there is nothing when you shift from park to forward or to reverse
05-07-2011, 12:46 AM
on
Yeah i think its just the linkage, get someone to shift the truck wile you look under neath, if you see that cable moves the lever on the tranny every time the shifter move into a different slot then the problem might be internal, but if it dosnt move then it could be the shifter having problems, so just give the linkage a check
04-13-2012, 10:58 PM
on
the trans went out needed a new one
04-14-2012, 12:21 AM
WOW! Update! Better late than never!
Bubba Jim
02-02-2014 10:03 PM
4x4jedi
07-10-2010 06:37 PM
falcon5spd
12-24-2006 11:35 AM
njtinman2
09-02-2006 02:25 PM
Shovelhead 93
01-06-2006 06:30 PM
1998,
1999,
4x4,
drive,
ford,
gear,
problems,
ranger,
specs,
swaps,
transmission,
truck,
v8,
wheel,
wont
