223 rebuild - advice sought
#32
#34
As that other Larry would say..... you are 'gittin er done'. I like the way you get right after it. I still have my front clip off because it's so incredibly easy to chase those last oil drips or wiring details or anything related. After I figure out my wiper conversion I'll fix my fenders and paint all the tough spots and button the whole thing up. Happy Wrenching!
#36
#37
#38
#39
Take some good measurements then have it made longer. Check around, there are shops that do this, usually in larger towns though. Probably Gary would tie one end to a tree and the other onto the biggest rig that he has and give it a tug to stretch it. Welding additional length onto the shaft is not all that tricky but it should be balanced after completetion. The last one I had done cost a little over a hundred bucks and that included new u-joints.
#40
What Spur said.... and actually I'd cut it in half in the middle and find a piece of pipe from something like an old swingset or electrical conduit for a sleeve, and weld it all up. Then I'd drive about 65 mph and if it doesn't shake apart, you're good to go. Actually I think you should go for the 100.00 professional job. I got license plates for my project yesterday while on the mainland and now I will be driving around a lot more and further (without the clip) and most likely worrying about which of my low budget projects will hold up and what will not. I'm thinking you will be using the emergency/parking brakes on the rear wheels, sorry I snagged the brake lever and linkage to bolt to my current tranny. GB
#41
Clutch mouse
No-go on the driveshaft. The output spline pattern on the 4-speed is similar to or the same as the crankshaft output spline pattern. The pattern on my driveshaft is around 30 splines. Heavy duty vs. light duty. I'll have to get a new shaft to use this 4-speed.
Speaking of heavy duty, that 4-speed is quite a chunk of metal. Twice as heavy by my feel as the 3-speed.
Gary, You sent me some additional material you probably didn't intend to send. The clutch housing was a mouse nest. If you're missing about 5 pounds of seat cushion batting, I know where it went.
#43
Do we all use the same clutch alignment tool?
I measured 1 1/8", 10 spline. Am I missing anything if I order this?
Dorman 14522 Clutch Pilot Alignment Tool 1 1/8" x 10 Spline 037495145220 | eBay
#44
#45
