Quick 390 rebuild for reliability and a lil power
I've been lurking here to learn a little about how you guys are getting powerout of these. I'm starting with a 76 4V motor. I'll have the heads apart for some re-seating and 3 angle valve job so I'll do a lil bowl work and thin the stems but no port enlargement. From what I gather here the trick is to use the 360 rebuild kit. I'll upgrade to the RV cam and find a used dual plane and headers.
Should I deck the heads to get rid of some of the recess?
Will this combo get me over 300hp reliably?
As for a 390 with some "grunt", the original poster is on the right track.
An "rv" cam is a toss-up though - post what cams you're looking at and these guys will pick 'em apart
As for the OP looking for a good used dual plane intake, the factory iron manifold will work just fine up to around 5500 RPM. Save your money, unless you happen across a killer deal. That money could be used for other stuff that would have a much better end result, like headers or better cam/lifters/timing set.
Granted, the iron manifold weighs about 45-50 Lbs more than an aluminum one, but how often do you plan to pick it up?
Here's my combo -- standard bore 390 (was a 2V out of a car) rering kit only with the following mods:
Edelbrock 1404, 500CFM:
Jets, .086/.098
Nozzle, .28, bottom hole on adjuster
Springs, Pink
Metering Rods, 65x47
Performer Intake
2 1/2" x 14" Air Cleaner
Hyd. Flat Tappet Cam (Melling MTF-4):
204/214 @ .050
.486/.512 Lift
104/120 Lobe Ctr.
107 Lobe Sep.
Comp 940 valve springs
Hedman Headers
Dual 2 1/2" Exhaust with Crossover, Behind Tire Exit
Walker SoundFX Mufflers
OEM 1974 Breakerless Electronic Ignition
11 Degrees Initial, 36 Degrees Total Timing
Autolite 45 .036 Gap
C6 Auto
Stock Converter
3.00:1 Gear
31" Tire
Nothing done to the heads (C8AE-H) other than lapping the valves with an electric drill, they already had hardened exhaust seats. I tow 4000lbs 400mi. to the drag races in Topeka a couple times a month with it in my 68F100 and get 10mpg at 65mph/2100rpm. I can get 14 on the highway without the trailer at 60. The truck just walks up some pretty good hills, even with last week's 40mph headwinds (took my mileage down to just under 9).
Jets, .086/.098
Springs, Pink
Performer Intake
204/214 @ .050
.486/.512 Lift
104/120 Lobe Ctr.
107 Lobe Sep.
Hedman Headers
C6 Auto
Stock Converter
3.00:1 Gear
31" Tire
I overhauled the 4 bbl 10 to 1 390 in my 68 Merc with a Crane 272* Energizer, left the C8AE-H heads as is, topped it with a 428PI intake, 3310 750 Holley and went with FPA headers. This combo would burn 89 octane fuel, idle had just a hint of a lope when cold, pulled from idle to 5500 rpms. The big Merc (4200 lbs) ran 14 flat @98 in the 1/4 with a 3.70 geared open diff 9" thru the stock C-6. I had a identical build in a 70 F100 in the 80's but with a 296* .516 lift cam (Cam Dynamics) and would run on 87 and run the 1/4 in 15's with a 3.50 rear.
Needsoles
05-24-2009 02:46 PM
BlueovalFE
15
01-09-2007 06:26 PM
kenwheel
07-24-2006 08:22 PM
dbossman
11-05-2004 03:55 PM
pward76
02-19-2003 09:34 PM
