HIO Silver's Lo-Buck Bumpside Build
#632
NO JOY
Filled her up with fluids, five gallons of gasoline, and completed the final wiring connections. Ignition on and the fuel pump primed the system and no leaks. Yay.
'Went to program the ECU via Bluetooth and nothing.... no communication btween the tablet and ECU. I verified at least 12VDC to the ECU and it checks out.
I'm gonna call Edelbrock tomorrow to see what is up. I read on their forums that early tablets/ECUs had connectivity issues. I think I'm in that group.
Stay tuned.
Stay tuned.
#633
Stay tuned.
Stay tuned.
Awesome build by the way, I love your attention to detail. Are ever going to paint it or leave it patina'd forever?
#634
I'm inclined to leave the outside the way it is at this point... less attention and less likely to get stolen. The only real clue that something is amidst will be bucket seats, a Grant steering wheel, the Hurst shifter arm, and a 5-speed shift ball.
Btw, I was told the large gash in front of the hood happened when the original owner's brother backed an agricultural combine into it.
#635
It comes with a base tune... but the tablet isn't even communicating with the ECU to load it. GRRRRRR. ...........I think I may have stumbled on the problem... it may be the ECU and tablet aren't "paired" because of the different serial numbers I just found.
I read the part about the hood, history's always neat.
#636
Definitely. I even disabled the Wi-Fi and left the bluetooth enabled and zero... zippo.. nada. No comms.
#637
I just watched popular hot rodding's setup video. They have their tablet plugged in to the wall via USB for the demo. It may not matter, or it might. The tuning software I use of for my bike won't write to the ECU unless it detects the laptop is plugged in on ac power. It's a feature to keep from bricking the ECU. Maybe Edelbrock does something similar. Also the Wifi icon in Edelbrocks' demo page is on, not off.
#639
Doesn't sound like the tablet and the ECU properly discovered one another. When you switch on a Blutooth device it enters a discovery mode in which it searches for the item it is supposed to connect to. If it has never connected to a particular item this may take a while, but it is uncommon now with the newer technology. You should also know whether or not they've connected. It would show up on the screen.
Hooray for wireless.
#640
#641
Tomorrow is another day... perhaps I'll have a clearer head to wrap around this thing. I'm gonna call their tech line anyway because the tablet has a different 'pairing' number compared to the label on the instruction manual.
#642
VROOOOOOOOOOM !
The Lo-Buck Bumpside ...... LIVES AGAIN!!!!!!!!
I started all over by going back to basics by loading and installing all of Edelbrock's latest software. It also turns out that the tablet and the ECU were incorrectly "paired" via Bluetooth. The different serial numbers did come into play but the instructions didn't mention what PIN to use so I figured the ECU's number made sense.
I stepped through the initialization procedure and on the second crank she lit off...'got her all calibrated and idling at 700 RPM. All the systems check out..... 195 on the water temp, 14.2 vdc on the charge (thanks 3G alternator!), and 20 inches of vacuum, 13.2 AFR at idle.... a little phat but I'll get to tuning her through the tablet soon enough.
She idles as smooth and silky like a 10-day old kitten but freckin' roars like a 700-pound lion through the modified Flowmasters.
Woooohooooooooo!
HIO Silver! Away !!
Woooohooooooooo!
HIO Silver! Away !!
