Misfire problems
I hate to say it, but it's not over yet... I was driving it today and noticed a definate drop in power and the miss is back, not quite as bad, but it is back. The engine also has a lot of blow-by, if you pull out the pcv valve it starts puffing smoke from both valve covers.
One more thing, I'm pretty sure it's a lean miss, I cranked out the idle screws all the way (any farther and they would fall out) and the motor ran noticeable smoother, but still missed. With the standard 2 1/2- 3 turns out it misses bad and runs real rough.
Sam
Sam
I think I finally have found what's been giving me grief, a warped head. The passenger side head had a big high spot in the middle of the intake surface. It looks like the shop goofed and missed that. The passenger side had had at least 0.013 in a 5 inch section. Driver's side had about 0.004 of warp over the length of the whole head.
So back to the shop they went, hopefully this will end my problems. I'm also going to pick up a stock iron 4bbl intake (the offy's power band was too high for me) and stick that on.
I'll report back when it's running again, hopefully I'll have some good news!
Sam
Sam
Wonder what happened that metal started getting into the oil? Might be the heads weren't cleaned after shaving, if this is the same machinine shop that sold you the heads. Losing 10 lbs of pressure is troubling too, especially when you didn't change anything with the crank. Where could the new leak be?
puttster
puttster
Unfortunately, the story isn't over yet.
I got the motor back from the machine shop last August or so, they changed the bearings due to pinging, but the knock was the fuel pump to chewing up the timing cover.... Nobody was happy when we found that.
So I put it back in and ran it around for a while, and the rockers kept getting noisier. No idea what was doing it, and then coolant kept showing up on one of the heads. Tried to fix that, and it slowed down a bit, but couldn't stop it. Then last week, it started pinging, pinging bad. Even running premium it would ping, normally I run regular. Pulled the plugs and several have aluminum flakes on them, but the #3 was especially bad. Did a compression test and #3 was 30-40lbs below the others. Plugs looks lean, so did the pistons.
I suspect my engine builder used the print-o-leaks on the intake and they're causing the coolant leaks. And if they're leaking coolant, I suspect they're leaking vacuum too.
I got a new truck to drive now, so I'll tinker with the old Ford, I'd like to put a diesel in it and put some patch panels into it for the rust.
Any idea what a fair price for the 390? Fresh rebuild, Edelbrock performer intake, Holley 570 carb some other goodies, potentially major pinging damage. $500 sound fair? I want rid of it.
Sam
Sam
mikey1968
23
08-14-2017 08:20 AM
1oldtimer
18
02-12-2013 02:23 PM
Tomget
16
12-17-2010 10:00 PM
