Have spark and fuel but no start
If you have spark I would think the ICM on the side of the distributor is OK.
Maybe low fuel pressure or bad spark plug wires or you may even have fouled spark plugs now.
You need to put a fuel pressure gauge on the fuel rail with the key on and pin #2 shorted to pin #6 of the self-test plug.
Also you need to see what codes you have.
how would you jump pin#2 to pin #6 you are talking about the EEC pins right?
on
Trav
the first time I pulled the ICM I cut the tool half why so I could get a 1/2 open end on it. I used my cut off wheel.
other words you will have to pull the distributor, be sure to mark with a sharpie
on
When I remove it on my trucks I had to pull the dizzy up as some other things are in the way but all you need tool wise is a 9/32 or 7/32 (I can't remember exactly) deep that is small enough to fit in there and take the bolts off then disconnect the wirring harness. There is 2 small bolts be very very careful not to loose them I lost one on our 89 F250 and had to have a small magnet find it I was lucky not to drop it in the engine.
Trav
Trav
cmdevildog16
05-16-2019 07:40 AM
MudBugn
04-14-2009 01:37 PM
North_of_60_F250
01-18-2009 02:48 PM
