Found a source for the IVS switch
  #61
Old 11-12-2013, 02:21 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel
OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
I bet that sort of behavior is in my future... I have a back-up one that I suppose I should swap in, but that one has 355k on it, whereas the on I'm using now that's going bad only has 200k on it. "only"
  #62
Old 11-13-2013, 01:39 AM
GSCPSD
GSCPSD is offline
GSCPSD is gaining momentum as a positive member of FTE.
The elusive IVS
I have a Mouser Electronics main warehouse/distribution retail outlet center located near my home and do business with them often. If one of the members here would be kind enough to send me an old non-working IVS switch I will personally take it to their customer service technical support dept and do my best to locate a suitable replacement.
  #63
Old 11-13-2013, 06:25 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Now that's what I'm talking about! I tried to send you some reps, but the site says no...
  #64
Old 11-13-2013, 06:35 AM
OldWoodsDiesel
even though, mine is acting up right now, if/when I do replace it, I think i'll keep it as a backup until I get a replacement.
I was able to rep you, though GSC...
And, if no one offers up a busted IVS for you to go to Mouser with, i'll take some good measurements and send them over when I swap in my other one.
the electrical function of the switch is pretty straightforward, its the mounting and electrical connections that would be nice to match up with a new part.
  #65
Old 11-13-2013, 08:27 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I'll keep that is mind GSC, when I get another and know mine is bad. Truck is still all apart, LOL
  #66
Old 11-13-2013, 08:56 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Thumbs up
Thats what I had in my mind when mentioned about a aftermaker replacement. Thanks for your offer, I also tried to rep you but Im in Jail
  #67
Old 11-13-2013, 09:47 AM
madpogue
madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
I've got a spare pedal assembly, I can take some close-up pics tonight, maybe with a tape measure.
  #68
Old 11-13-2013, 03:35 PM
Farmboy1539's Avatar
Farmboy1539
Farmboy1539 is offline
Farmboy1539 is starting off with a positive reputation.
Thanks as well for the offer!! Reps sent
I'd send you mine but it's my daily driver and still working enough to get me around for now.
X2 on trying to get some pictures.
  #69
Old 11-13-2013, 11:48 PM
madpogue
madpogue is offline
Pics:
Removed from the pedal. It's aprx. 2" wide by 1.625" high, with the pin not pressed (contacts closed).
Installed on the pedal, with the stop pressing the pin (contacts open). Pin travel is only about 1/16", maybe 2mm.
Connector; hopefully that'll help determine the connector type / terminal size. 'Course, it's only a switch; splicing in another connector would def. be on the menu.
  #70
Old 11-14-2013, 06:06 AM
OldWoodsDiesel
i assume those rivets (in the upper corners of the switch on the top two images) come through that mounting plate. the on that I posted a link to had two mounting holes that might be close to those locations. ...at least maybe its a starting point for their search at Mouser. like the connector, though, having those holes line up would be nice, but it'd be easy to drill new holes in that mount bracket.
good work with the pics MP!
Edit: nevermind about the holes matching up to the one posted. the hole spacing on the datasheet of that part is 5mm (just under a 1/4") whereas we need ~1-5/16" the switch button does look like a pretty close match. maybe that same manufacturer makes something like we need! here's to getting my hopes up!
  #71
Old 11-14-2013, 08:19 AM
madpogue
madpogue is offline
Correct - the switch proper is riveted to that L-bent bracket, which then bolts to the pedal assembly with a torx screw.
I forgot to yo-yo the thickness of the switch, but I guesstimate it at 8 or 10 mm (5/16"-3/8").
I'm not finding anything on that Mouser site that matches the configuration of the mounting holes, the pin/plunger and the connector. Maybe just putting the pics on a mobile device and taking it into various electronics supply houses to show the dudes would be the way to go.
  #72
Old 11-14-2013, 09:46 AM
OldWoodsDiesel
i agree - there are literally tens of thousands of similar functioning switches at mouser. hopefully someone there with some experience can find something a lot quicker than we can clicking through thousands of part numbers.
Newark Electric (in North Jersey) might be worth a try as well if anyone here lives near there. DigiKey is another huge electronics supplier, but I don't know where they're located and they're more Printed Circuit Board specialists, I think.
  #73
Old 11-14-2013, 09:49 AM
OldWoodsDiesel
oh, and for whoever can actually go in and speak with someone - be sure to lay it on thick: "I know of literally HUNDREDS of guys who need these switches and will buy online."
100*$2/per switch is literally hundreds of dollars of sales for these companies!!! though I guess in reality, we're talking TENS of guys rather than hundreds :-)
  #74
Old 11-14-2013, 10:18 AM
oldbird1965
But the tens of guys plus others will buy two or three to have spares. At the beginning of this thread over hundred, I think without going back, were sold and then they were sold out and have been for over a year.
  #75
Old 11-14-2013, 10:33 AM
Hussler's Avatar
Hussler
Hussler is online now
Hussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to behold
More can be made, someone just has to order the minimum quantity, which is 100 or 125 depending where you look. I sure Mouser could order them if they wanted to. Personally, I'd like someone like Riffraff Diesel to get involved.
Quick Reply: Found a source for the IVS switch
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
