1956 F100 Hidden VIN Locations - HELP
More problems in NC
How about some opinions about this. I recently bought a 56 F100 frame that came with a Va. title in the sellers name. The vin # on the VA. title was a 7 digit number that starts with MA. The seller, who had owned the entire truck since the early 80's, told me that he had bought it in Maine originally and that Maine had assigned it the MA#. When he moved to Virginia, they just put that number on their title and off it went. I can plainly see the Ford vin# on the top of the frame, right front. I am wondering if it would be wise for me to stamp the MA# in the frame beside the Ford #. I am sure that a DMV guy will have to see the frame before a title would be issued. Also, how much of a truck do you have to have before you can get a title. The frame is a roller with engine and trans, no sheet metal at all. The original body was stolen from a body shop in So. Va. some years ago. Thanks for the feedback.
I found the one on my 55 just in front of the cab on the passenger side. On top of the frame rail. It was totally covered in years of grime. I kept spraying the area with simple green cleaner and scrubbed with a wire brush. It is very faint but I located it. Another problem could be if your frame was painted since you mentioned the other one was taken off. In this case it may have been filled in with paint and there's no way to find it unless you strip it all again.
Maybe someone else can help you out more. Good luck though.
It wasn't hard to see mine at all and it was completely legible after a quick wire brushing.
No such thing as a VIN on any pre 1949 FoMoCo Passenger Car or pre 1948 FoMoCo truck.
These vehicles were registered by their specific engine number that was also stamped on the hogshead. It was not stamped anywhere else.
The problem was, when the engine was changed, the numbers no longer matched. The VIN (Vehicle Identification Number) registers the entire vehicle.
Les Kelley, the largest used car dealer in the world and a Ford Dealer (Kelley Kar Co., located on downtown LA's auto row-Figueroa St.) came up with the VIN system.
FoMoCo went with VIN's in 1948 for trucks, 1949 for Passenger Cars. Before too long, all the automakers adopted it. Kelley also founded Kelley Blue Books.
And btw: Kelley Blue Books that were issued to car dealers, banks, finance and insurance companies listed the location of every automakers hidden VIN
Quoted from the Vanpelt Sales LLC website:
From 1932 through 1948 vehicles, Ford Motor Company stamped the serial number into the top of the driver's side frame rail in three locations.
This same number was also stamped into the top of the transmission-to-engine housing portion of the transmission. This location was visible when the
floorboard and transmission cover plate were removed (click here for a picture example). Of the frame-stamped serial numbers, only the forward-most
stamping was visible when looking down into the engine compartment (located between the front crossmember and the dash (firewall). The two other frame
locations are visible only when the body is removed from the frame. The serial numbers were metal stamped with numbers/letters approximately 1/4" in height.
Visit this link for more info on the subject. Everything here I've found to be true thus far, so i have really no reason to question them.
Early Ford Serial Numbers For Cars and Trucks Manufactured for the USA Market from 1932 to 1953
The guy's story may be legit, and for your sake, let's hope it is. It would be nice to have some proof to go with it, like a police report or something to document the loss. Every state is different. Do you have to have the truck inspected before you can transfer the title? Some states, like Washington, require a full running and roadworthy vehicle before they will inspect it. There's no way a rolling chassis would ever pass inspection here. But with a title, I can get it transferred to my name with no questions asked.
It all depends on how many red flags you want to raise. You could check with Maine to get some verification on the assigned vin, if they'll tell you anything. You could find out more about the stolen body story to have something to back up the claim, in case you ever needed it. Or, just let sleeping dogs lie and not worry about it until you have to. It's an interesting story. Keep us posted on how it turns out.
NC TITLE
Finally!!!!! I got throught the NC Special Titles Unit and have received the clear title on my 56. I convinced them that the 57 VIN tag was attached differently than the 56 by the many photo's and comments I received from FTE members and some from Ebay photos (over 30 photo's of 30 different VINS). It only took 1 1/2 years to get them to clear the title while my truck sat in the building. The local DMV Inspector was as frustrated as I with the "stubborness" of the Raleigh main office.
